400 cu. In. Small Block Chevy Motor
For sale carb to pan 10.3 compression-pump gas motor Dart 31131213 LiL M Block Scat 4-350-3750-6000-3S Super Lite Crankshaft Scat 2-350-6006-2100SA Con Rods SRP 231308 flat top pistons Airflow Research 235 heads Comp Cam solid roller cam 264 deg. Intake, 271 deg. exhaust duration, .673 lift Comp Cams 96818B-16 Elite bronze bushed roller lifters Comp Cams chrome moly pushrods Jesel KSS-416060 1.6 shaft rockers Airflow Research valve covers Edelbrock 2925 Super Victor manifold Holley 950 HP 0-80496-1 Carb MSD 8570 Distributor MSD Crank Trigger system Milodon 30900 Oil Pan Milodon oil pump and pickup Rollmaster timing chain set ATI Balancer 917781 Moroso 4 vane vacuum pump Moroso vacuum pump drive MSD Dyna force starter 5095 168 Tooth SFI Flex plate This is a great motor that was built to run trouble free as a street/race motor. I used it mainly to go to cruise nights. No spare time limited me to going to an occasional track rental. It has low street miles and small number of runs on it. It ran a best of 10.15 @130 in my 3300 lb car. Parts to build would be over $15K. Will sell for $9250 I’m in Connecticut. Call or text: 860-614-2252 Email: 1984iroc@gmail.com Last edited by Charlie Laraia; 02-08-2020 at 02:33 PM. |
