Old 05-15-2020, 10:37 AM   #1
Mark Ugrich
Liked 71 Times in 38 Posts
Default Roller cam bearings
Are there any real advantages to using a roller vs. a Babbitt bearing? I’ve never had any personal experience using them.
Old 05-15-2020, 01:49 PM   #2
FED 387
Liked 334 Times in 181 Posts
Default Re: Roller cam bearings
depends on the application--
Old 05-17-2020, 02:31 PM   #3
voltdr
Liked 100 Times in 51 Posts
A very good friend of mine that knows a few things about engine building and find HP told me that when the engine is running, the camshaft is spinning on a film of oil. It isn't dragging against the bearing material.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 05-18-2020, 11:07 AM   #4
Mark Ugrich
Thanks to everyone for your comments and insights. I think I’ll stick with Babbitt bearings.
Old 05-15-2020, 03:37 PM   #5
nhramnl
Liked 358 Times in 83 Posts
Really interesting question. A person's intuitive reaction would be "of course, look at things like roller lifters and rockers", but I'll bet there aren't many engine builders who have actually done an A-B-A comparison of cam bearings.
Old 05-15-2020, 04:46 PM   #6
SSDiv6
Babbitt is the only way to go.
Roller bearings, when turning the camshaft on the engine stand, the camshaft feels drag free and it turns easily. However, during engine operation and load, there is more drag while turning. When using high spring pressures, the loading may cause the needle bearings to fail.
Old 05-15-2020, 06:27 PM   #7
Todd Gross
Liked 54 Times in 24 Posts
The biggest advantage of roller bearings are that they do not need pressurized oiling. So in most V8's you are blocking off 5 oil leaks inside an engine.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 05-15-2020, 07:20 PM   #8
HP HUNTER
Liked 373 Times in 129 Posts
YES
Old 05-15-2020, 07:59 PM   #9
Mark Ugrich
So the advantage would relate to less oil coming from the cam journals, reducing windage in the crankcase?
Old 05-16-2020, 04:21 PM   #10
SSDiv6
The roller bearings still need some pressurized oiling; they do not oil by themselves and although there are claims oil splash is enough, I have seen enough damaged roller bearings due to lack of oiling especially on endurance engines.
If you have the right cam journal an lifter bore clearance, you will not have to worry.
Yes, they are known to create harmonics issues and it shows in Spintron testing.
