Liked 530 Times in 76 Posts
I’m certain this topic has been here before, apologies to the veterans.
I’m interested in reading the opinions of S/SS racers. Which harness are you the most comfortable with, and which lock mechanism, camlock or latch, is preferred? I’m sure we’ll all agree that safety is nothing to be cheap with, so expense is a non-factor. I’m specifically interested in what Belts should be run in Stock, L and lower. I’ve read that OEM is still an option?? I’m just trying learn as much as possible before strapping myself in a 12 second rocket ![]() Thank you CR members.
7350 Stock Eliminator Quite possibly the only member to REDLIGHT their join date ![]() |
Liked 431 Times in 224 Posts
My personal logic is to use latch-link belts in a slow door car and camlock in anything else.
The latch-link are about half the price, and in a roomy car with a thin jacket and no gloves or arm restraints they are very easy to use. I've never found a notable difference between any of the several brands that I've used.
S/ST 51 S/C 53 |
Liked 1,987 Times in 599 Posts
I have used both types of latch. One is not any better than the other. The cam lock is more expensive. Both work well. The GForce stuff is good.
Mike Pearson 2485 SS |
Liked 314 Times in 177 Posts
For your application, a 12 sec. car, I would recommend a lap latch belt. With quicker combos a cam lock system with crotch belt is the way to go. I prefer that the crotch belt holds the mech. and it appears that the manufactures have switched and started placing them on a side lap belt. I usually take them apart and switch it however sometimes this is not possible. Choose a brand name that is readily available, consider replacement in two years, contingency (ha). Also mounting requirements.
We run a couple of M/N/O/P race cars and trucks.
As I recall = M/S up requires a Rollbar/Harness BUT we run a Rollbar/Harness in everything! You are at risk of getting HIT in the side or back by a 150+ Stocker even if you are only going 100 or 110. The Cam lock is easier to use in confined spaces for my elderly fingers! On the other hand......In the slower racers = I don't bother with a Fire Jacket Accidents are much more a concern to me than a onboard fire ( Ever since I removed the Nitrous from my Stockers ).
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 05-28-2020 at 03:49 AM. |
Liked 93 Times in 29 Posts
On a side note, although it's not the biggest cost on a race car, with all that's going on, how about an extra year on expiriry date from NHRA for existing belts.
#7 | |
I can only hope to have a "window" race with you one day GTX John ![]()
