Old 11-01-2007, 02:49 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Gas question??
OK here's the thing....when i bought the car they ran C-12 in it.....I drained everything & put in Sunoco purple....car slowed a .10 what do i need to do to get the .10 back? NO I'm not going back to C-12!
Old 11-01-2007, 05:53 AM   #2
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default Re: Gas question??
Greg, I dont know the exact difference from C-12 to Purple, but I would play with jetting and timing first. I know with our car going from 93 Pump to C-10(unleaded), I had to make a conisderable fuel and timing change to get it to run the same. 93 being the quicker of the two in the end. Stupid 93 will give us problems at nationals though.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 11-01-2007, 06:52 AM   #3
Joe DeMarzo
Liked 121 Times in 11 Posts
Greg, it is in the jetting. I have used sunoco purple until this year and never saw any difference with the right jeting. In fact this year I used c-11, came in the car when I recieved it, changed to c-12 and it picked up .06. because it was to rich with the jetting. You will probably need to lean it out, C-12 burns hotter that the sunoco purple. Great article years ago about low compression motor and the rpm it takes to burn racing fuel, if I find it I will forward it.
Good Luck
Joe DeMarzo 1317 STK
Old 11-01-2007, 10:15 AM   #4
Oldtimer
Its really caused by the viscosity, the rate of which the fuel goes thru the jet. Jetting is the correct answer.
Bob Pagano L88BOB@aol.com
www.dyainc.org
4033 AA/SA
Oldtimer is offline   Reply With Quote
Old 11-02-2007, 01:59 AM   #5
greg fulk
greg fulk's Avatar
Smile Re: Gas question??
Thanks guy! I was hoping it was timing....alot easier to change then jets (to me anyway i don't know a thing about a Q-jet) I can say one good thing the car runs pretty close...in bad air @ columbus 12.92 (week before sports nationals) to fall classic good air 12.77.....i can live with that. thing is car went 12.71 @ U.S. Nationals.
Old 11-02-2007, 07:03 AM   #6
Joe DeMarzo
Greg, depending on the jets, you may only have to change the rods? What do you have in there currently for rods and jets?
