Old 08-10-2020, 10:15 AM   #1
novassdude
Liked 136 Times in 49 Posts
Default 39’ 2001 Damon Escaper Diesel
I am looking at a motorhome that I would pull my 28ft aluminum trailer loaded will be under !0,000# It has the Cummins 350 ICS motor with an Allison 6 speed automatic transmission.
Any one have any experience with one of these towing?
Thanks John
novassdude is offline   Reply With Quote
Old 08-10-2020, 03:52 PM   #2
GTX JOHN
Default Re: 39’ 2001 Damon Escaper Diesel
We pull about double that much with our similar combo.
However:
We have the big Trailer Toad.
We are VERY Slow going up hills.
We have heating issues when it is HOT out
here in Desert and have to slow down to keep
under 220 Degrees where it defuels especially
climbing up hills.
We have only about 30,000 miles on our unit.
John Irving
741 Stock
741 Super Stock
Old 08-10-2020, 10:33 PM   #3
lorenr
Liked 19 Times in 9 Posts
Thumbs up Re: 39’ 2001 Damon Escaper Diesel
The only thing I can say is that you should be sure that it has a side mount radiator. It should also have the hydraulic fan drive.
Cooling the radiator is everything. Even most side mount radiator systems have additional electric fans on the other side of the chassis, blowing air across motor and engine housing to the radiator
I used to have the ISC cummins in a 36 foot Monaco set up as above.
Now I have a 40 foot Monaco with the ISM 500 motor and Allison 4000. What an unbelievable difference. Climbed a really long, very steep grade at 45 MPH with a boat and trailer (about 7000 lbs., rig is another 41,000) Trans saw 175 degrees (highest I've seen it get) motor went to 205 degrees.
Now, those older ISM 500's are cheap, very durable and don't need DEF. They also come with a Jacobs Brake which is everything.
lorenr is offline   Reply With Quote
