Old 09-28-2020, 10:05 AM   #1
Jeff Stout
Liked 707 Times in 284 Posts
Default Hot Tip for setting ignition timing
When using a stock balancer and you have 2 marks on it, one for top dead center and 1 for your desired total timing. Always know which one is which. My pathetic performance yesterday at Az S/SS event was due to setting timing at top dead center mark. I wondered why car started up so easy and I had to reset idle. Another lesson learned on how to slow a car down and lose a race. I think the heat got to me.
Old 09-28-2020, 10:32 AM   #2
nhramnl
Liked 358 Times in 83 Posts
Default Re: Hot Tip for setting ignition timing
Really simple solution that I've used for a long time... I clean the balancer really well (with Brakekleen), then find the timing mark I want (which, in your case, just has to NOT be the TDC mark) and I carefully "paint" the mark with White-Out. When the timing light is strobing, the painted mark just glows, and is impossible to miss. Hope that helps.
Old 09-28-2020, 11:23 AM   #3
Jeff Stout
I will make tdc mark disappear today so to only have 1 mark for total timing. Your right, clean and fresh white out. I checked because of new MSD ignition was installed and wanted to double check.
Old 09-28-2020, 11:49 AM   #4
bykr
Liked 167 Times in 81 Posts
Probably ran a little hotter than normal too.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 09-28-2020, 05:35 PM   #5
jim hensley
those little white paint pens work well.
jim hensley is offline   Reply With Quote
Old 09-28-2020, 08:48 PM   #6
MRE 7171
Liked 127 Times in 26 Posts
Jeff how much slower did your car run from your normal timing
MRE 7171 is offline   Reply With Quote
