The car is starting to leave better.
Looks great. What combo do you have in it? Motor, tranny and rear gear?
Well it certainly isn't stock legal!
3525 lbs 468 13:1 AFR 305's Vic Jr. HP 1000 2" Hookers GZ pump TH-400 ATI Treemaster 5800 flash 4.30's Hoosier 30 x 9 radials Launch at 1500, shift light comes on at 6300/6800 stripe at 7300. Best 1.340 3.96 6.18 @ 110.79 8.10 9.73 @ 137.44 |
Man it looks good. I tried 2" headers on my 427 BBC and it killed the torque. I have the same car, same rear set up small tire turbo 350 and gone 9.89et 1.37 60' but don't look that good. What kind of conditions are you running in? I bet you have more et there. I went 9.89 at 133
You must have 725 horse I'm guessing. Last edited by 67camaroracer; 11-10-2007 at 04:40 PM. |
That pass was off the trailer right before the ring gear broke! On the next pass I heard a noise in the rear on the shutdown and decided to load up. I found several broken teeth on the ring gear the next day. I just finished buttoning it back up with a new 4.33 Pro Gear. I'm certain the car will go into the .60's under similar conditions. The DA was 213' that day.
Last year with 1 7/8" headers it went a 9.83 @ 136.01, 1.349 60 foot with a strong tail wind in 850' DA. |
Pretty good conditions compared to Lebanon Valley Dragway where i run. Still can't figure out how your running such a small primary tube. It must be the difference between the AFR exhaust port and the Merlin exhaust port.
