Old 06-10-2021, 07:38 PM   #1
hotrods1795
Liked 2 Times in 2 Posts
Default C-16 fuel in a stocker
Do I have to change the timing, is there any advantage in et.
Any information if appreciated.
hotrods1795 is offline   Reply With Quote
Old 06-10-2021, 08:02 PM   #2
GTX JOHN
Default Re: C-16 fuel in a stocker
Our Demons figure @ 11.8 to 1 and run the best on C11 even
with timing on the edge of Detonation last couple hundred feet.
What combo are you racing and how much compression?
John Irving
741 Stock
741 Super Stock
Old 06-10-2021, 08:18 PM   #3
hotrods1795
63 Dodge Polara - Max Wedge 13.5-1
Do I need to re-jet carbs or anything with timing?
Old 06-10-2021, 08:23 PM   #4
mschafer
Liked 13 Times in 9 Posts
Smile Re: C-16 fuel in a stocker
I am not a fuel chemist, but to my knowledge octane reduces detonation in higher compression engines due to slower burn time, in a stocker with lower compression C16 it would only slow it down,as it burns slower, I agree with GTX John on C11.
mschafer is offline   Reply With Quote
Old 06-11-2021, 12:06 PM   #5
Race Clean
Liked 129 Times in 53 Posts
It works good in supercharged engines
Stop global whining
Race Clean is offline   Reply With Quote
Old 06-11-2021, 09:11 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
I would check if c11 has enough octane for 13.5 to 1 compression before using it.
Old 06-11-2021, 09:22 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I use C-12 13.8 to 1. Big Block Chevrolet.
chris ok is offline   Reply With Quote
