Old 10-25-2021, 05:59 PM   #1
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Stock Auto Trans Rule Change History ?
Hey guys, in NHRA, what was the 1st year a combo that came with ONLY a 2-speed auto trans, could use a 3-speed auto trans ?
Common example would be the PG Chevy combos that could then use a TH350, because of the new trans rule.
For those of you who had some 1st hand experience with a Chevy PG equipped Stocker combo, that switched over to a TH350, what was the aprox ET change ?
Aprox how much quicker is a common Chevy Stocker combo with a 200 trans, than with a 350 trans ? I'm talkin about both trans having the very latest & quickest upgrades. Another way to ask it may be: How much quicker is the best currently available 200 trans vs the best currently available 350 trans in, let's say, a popular sbc Stocker combo ?
Thanks to those who have the time & will relate their experience in this area !
Old 10-25-2021, 06:08 PM   #2
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Default Re: Stock Auto Trans Rule Change History ?
Thanks to those who have the time & will relate their experience in this area ![/QUOTE]
Hi
The short answer is - pretty darn close..... the difference ends up coming down to the combination of first and second gear ratios that work best for you.... the (high end) 350's have a few more of these combos available than the 200 does... The other factor is, of course, how much experimenting you are willing or able to do.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 10-25-2021, 09:52 PM   #3
Liked 5,142 Times in 1,963 Posts
Hi
I don't remember the exact year but it was in the last decade.
S/S was first, then Stock, then 4 speed stick shifts. (oh yeah, then clutchless in S/S)
The 3 speed deal wasn't put in to benefit the little guy with a 67 Camaro..Trust me.
I would say that if you took a 350 and put in a 2.75 low , an aluminum direct drum, and were really good with a lathe, you could come pretty close to an entry level 200 like I build.
The Pro Trans and the Coan are in a different league. As Ange said, lots of different ratios available too.
Old 10-26-2021, 12:17 AM   #4
oldskool
oldskool's Avatar
" I don't remember the exact year but it was in the last decade..."
So, for a popular sbc combo that previously had to run a PG, aprox how much quicker could they run, with a good 3-speed ? Hey, I'm just assuming they ran quicker.
I know that lots of bracket racers run a Glide, for consistency & less traction problems. Just assume that most former PG Stock racers choose to now run a 3-speed. Is this correct ?
Old 10-26-2021, 01:03 AM   #5
How much quicker? Usually some, if you can hook it.
Most PG's are now 200's except for maybe 67 oval port Corvette.
Old 10-26-2021, 09:32 PM   #6
Gmirza
Liked 253 Times in 95 Posts
The rule change was around 1990. Give or take a year.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
