Old 11-14-2021, 11:09 PM   #1
3354 C/AA
Default Racepak, MSD, Strange, Barry Grant, Cylinder Heads, Intakes
***Gear Sets***
Strange Aluminum Carrier (Used) ***$950***
*40 Spline Strange Steel Spool (Used)
*Low drag Ball Bearing Pinion Support (used)
*4.88 Richmond 9310 Pro Gears (Used)
*Includes Shipping Container
***Ignition Boxes***
MSD 7530T Ignition box (Used) ***$390***
* Tested good from MSD
* OE Harness and cable included
***HEADERS & COLLECTORS***
Dynatech Merge Collectors (Used) ***$175 each***
*2.125 primary, 3.5 outlet. Factory Ceramic coated
***Shocks and Springs***
Koni Electric Shocks ***$1000***
* Used 2010 to 2014 Season
* GMM Air Sweeps
* Gen 2 MSD Style Control Box
* Comes with spring Bearings
Eibach 2.5x14.00 200# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 200# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 225# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 300# Springs (Pair) NEW! ***$50***
***Engine Valve Springs***
PAC-1370L QTY 8 NEW! ***$250***
PAC-1355H QTY 13 NEW! ***$300***
***Fuel System***
Barry Grant 400 Fuel Pump (Used) ***$125 each***
Barry Grant 2 port regulator (Used) ***$25***
***TRE Tunnel Ram Dominators (Used) ***$1200***
* Holley 4500 Style
* 1.83 Venturi
* 2.125 Blades
* Billet metering Blocks
***Engine Top End***
*2013 MBE Splayed Valve Cylinder Heads 16 Runs Last Freshened 04/2018 ***$7500***
*These are MBE/DART Casting, cast Heads. No GM Part Number
*Xceledyne CRN Titanium Intake Valves
*Victory DLC Titanium Exhaust Valves
*Setup for PAC 1355H
*Jesel Aluminum (solid body) Rocker Arm Set with hardware and Stands
*2.0 Pivot Length
*1.85 Intake Ratio
*1.85 Exhaust Ratio (1.75 Ratio available as Option or in additional for extra $800)
*Ball Type Adjuster
*Needle Nose Bearings
*-10 Vacuum Pump Connection
*HRE Intake Manifold, Dual 4500 Top, includes drop-ins, Billet Runners, -12 Vacuum Pump connection, For 8.900 Deck
3354 C/AA is offline   Reply With Quote
Old 11-15-2021, 02:21 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Racepak, MSD, Strange, Barry Grant, Cylinder Heads, Inta
You have a PM.
Todd Bailey is offline   Reply With Quote
Old 02-12-2022, 01:56 AM   #3
Jbe1
Jbe1's Avatar
Liked 14 Times in 1 Post
Pm sent
Jbe1 is offline   Reply With Quote
Old 02-12-2022, 11:16 AM   #4
Chris Knudsen
Liked 49 Times in 10 Posts
you have pm
Chris Knudsen is offline   Reply With Quote
Old 02-12-2022, 07:45 PM   #5
Joey Bohannon
Liked 61 Times in 22 Posts
I will take the O2 stuff if available.
Joey Bohannon is offline   Reply With Quote
Search this Thread:
Advanced Search
