Old 01-28-2022, 05:47 PM   #1
Terry Friar
Liked 16 Times in 2 Posts
Default Transmission shield fit?
We're running a '69 Chevelle with "stock" engine/trans placement. It's a powerglide. I originally tried a TCI aluminum trans shield, but there was no way it was going to fit. It was hard into the tunnel and the trans still needed to go up about an inch or so. I've been running a Stroud blanket, but I'm constantly fighting to keep the ends of attaching straps from hanging down... as in multiple zip ties! Is there a good fitting aluminum shield for a glide that will fit the stock tunnel? Thanks!
Terry Friar is offline   Reply With Quote
Old 01-28-2022, 06:33 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Transmission shield fit?
This is probably not all that helpful, but I'd highly recommend an aftermarket transmission case that removes the need for an additional shield.
It'll fit, and in my opinion greatly simplifies the transmission installation/removal process in addition to being more durable and probably safer.
S/ST 51
S/C 53
Old 01-28-2022, 07:25 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
If it’s a race car cut the tunnel and raise the tunnel wher needed.
Mike Pearson 2485 SS
Old 01-31-2022, 11:05 AM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Ditto. I took a torch and a BFH to my 68 Mustang to get a C4 with a shield to fit.
Dale Shearon
68 Mustang 6394
Old 01-31-2022, 01:12 PM   #5
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Transmission shield fit?
Good morning Terry,
In my 1969 Chevy Nova I used a shield from TSR, and I had to "dimple" the floor where the fire wall and floor seem join's together. The shield that Chris and Craig sent me fit the trans case pretty close, but there was two pronounced corners on the top of the shield, just behind the bellhousing transition. That's where I had to "dimple" the floor. Other then that the shield fit pretty good. Maybe give TSR a shout and see if they can help you out.
Also loosen the hardware and try pushing the shield to get it as close to the trans case as you can & retighten all the hardware. Check the fit.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 02-01-2022, 07:29 PM   #6
Terry Friar
Originally Posted by Henrys Toy View Post
Good morning Terry,
Respectfully,
Thanks for the suggestion Henry!
Old 02-12-2022, 07:17 PM   #7
Chevy55
Banned
Liked 179 Times in 89 Posts
I cam across this, thought you might find it interesting.
How to install a JW Ultra-Bell Housing without ruining it and make it look factory
Chevy55 is offline   Reply With Quote
