Old 05-13-2022, 10:06 PM   #1
mike britt
Liked 66 Times in 31 Posts
Default Fast xfi
Can anybody tell me how to set the timing in easy to follow English. The instructions are a little confusing to me. This is on a TPI 350.
mike britt is offline   Reply With Quote
Old 05-14-2022, 07:54 AM   #2
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Default Re: Fast xfi
Go to ignition parameters. Set the box next to fixed ignition timing to whatever you prefer it be checked at (I use 30). Then check the box for fixed timing and click apply. Check your timing and if it doesn’t match move the distributor until it reads 30°. When done deselect the fixed timing box.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 05-15-2022, 08:51 AM   #3
nolongerracing
Liked 72 Times in 27 Posts
Shouldn't you be changing the crank reference angle? I thought once the distributor was installed correctly and rotor phased, you shouldn't need to move it?
nolongerracing is offline   Reply With Quote
Old 05-15-2022, 03:18 PM   #4
mike britt
And that's the way I read the instructions but it makes no sense to me. The instructions don't say anything about moving the distributer to set the timing.
Old 05-15-2022, 04:14 PM   #5
Signman
Liked 269 Times in 99 Posts
When getting into computers back in the 90s realized I had to think like the computer my process didn't matter to it. Plus you have to understand what it sees and what it doesn't.
The ecu has no way to know what the actual timing is. It goes to the timing map and commands what ever the value is in the cell being used.
The timing offset helps get the actual timing close to what the ecu will command after phasing but you still need to match it with a timing light to match what is commanded to the actual value.
Have used the same method described above plus check it again after releasing the lock to match what cell is being used live on the laptop.
Old 05-15-2022, 04:42 PM   #6
B Parker
Liked 2,354 Times in 466 Posts
Jimmy I'd like to know how you put a carb on one of these things.
Old 05-16-2022, 09:13 AM   #7
countrypuppy4865
I don't think that would work, but an MSD Grid might be helpful!
4865 E/SA '04 GTO
