Old 09-09-2023, 08:41 PM   #1
Cody Phillips
Liked 41 Times in 15 Posts
Default Super stock EFI engine, trans, and converters
•2015 6.2 Camaro 376 LS
Built by Jeff Taylor new in summer of 22’
Has less than 35 passes since brand new and half of those not full passes
Will go 9.0s in GT/DA weight (normally run it heavy, restrictor, and heavy oil and go 9.30)
Can call Jeff to confirm components inside
Comes throttle body to pan
$27,500
• stocker LS1 was in my corvette will go 1.00 under and if in a stick combo more $12,000
•Brand new zero runs stock case Coan XLT 350 with brake, stefs pan, all the goodies, 2.41/1.52 ratio PG shaft, and CSR carbon shield $6500
•10 passes from new Coan XLT 350 with full aftermarket Case, all the goods inside, 2.55/1.58ratio, trans brake, PG shaft $7500
•brand new steel 7” converter from A1 performance made for LS, PG spline, set up to stall 7000-7200 behind motor listed above $1350
•brand new Coan billet 7” bolt together converter, set up to stall 7000-7200
Behind motor listed above made for LS. PG spline. Part number for converter is COA-20660x code TX-375+1520 $3500
•New US gear 5.29 9” $350
•Like new precision 3 speed clean neutral black shifter $500
•used strange front disc brakes complete kit (came off my corvette) perfect working order just upgraded $600
Also have 1995 grand am super stock roller for sale at end of season head to toe brand new in fall of 2021. Absolutely gorgeous car complete roller $43k or minus Holley EFI and Holley Dash $40k
Call or text 9107851660 -Cody
Phillips auto body Custom paint
Lumberton, NC
910-739-7171
Cody Phillips is offline   Reply With Quote
Old 09-23-2023, 02:53 AM   #2
pasi
Default Re: Super stock EFI engine, trans, and converters
Cody, You have private message
pasi is offline   Reply With Quote
Search this Thread:
Advanced Search
