Old 02-08-2024, 08:27 PM   #1
e vassar
Liked 272 Times in 108 Posts
Default Towing/Hitch questions
I have a 24ft enclosed trailer. I carry a 3100lb car,a scooter and a few tools.
I was towing with a Nissan Titan crew cab 1500 5.6 gas engine. It did pretty well but after installing air lift bags and a very heavy hitch with a torsion bar style anti sway system the truck would still take a dive when other vehicles would be about even with the rear of the trailer on the highway. I recently sent the Titan on its way,and bought a 2014 Silverado 2500HD Duramax. It is not a 4X4 but has the Z71 package so it sits up pretty high. I know I will need a drop hitch, and I don't mind using the one I have, but will I need to worry with these damn torsion bars to control sway?
Old 02-08-2024, 09:13 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
Default Re: Towing/Hitch questions
The torsion bars are to distribute the weight not control sway. They do make sway control. I would continue to use the torsion bars.
Mike Pearson 2485 SS
Old 02-08-2024, 09:32 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
This is what you need and want, none better!
https://www.equalizerhitch.com/
Old 02-08-2024, 10:46 PM   #4
e vassar
The one I have is a Husky. The torsion bars are slightly different, but otherwise same hitch.
Old 02-09-2024, 12:59 AM   #5
1700camaro
Liked 226 Times in 115 Posts
We use this one but had to buy a bigger drop for the shank. We pull with a 2023 3500 Duramax Dually & have a 34' Vintage bathroom package trailer.
Make sure you have your set-up according to the instructions & it covers your trailer tongue/gross weight.
https://proshop.summitracing.com/parts/CHT-17501
1700camaro is offline   Reply With Quote
Old 02-09-2024, 11:33 AM   #6
Steve Grady
Steve Grady's Avatar
Liked 137 Times in 46 Posts
A Reese "Dual Cam" sway control with a Reese weight distribution hitch to match your tow vehicle and trailer weight is a Very Good system to use when towing enclosed trailers.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 02-09-2024, 12:17 PM   #7
1320racer
1320racer's Avatar
no comparison to the equalizer hitch which is also made in America unlike the husky
Old 02-09-2024, 03:45 PM   #8
Mike Pearson
That system is superior to the old style with the chains for connections at the trailer. I have never seen that type. I have a gooseneck and a toter though.
Old 02-09-2024, 04:05 PM   #9
1320racer
1320racer's Avatar
Mike, it really is, sway control and load distribution all in one.
Old 02-09-2024, 07:01 PM   #10
Chevy55
Banned
Liked 179 Times in 89 Posts
Drop some pressure in the air bags and see if that helps the sway problem.
Chevy55 is offline   Reply With Quote
