Old 06-16-2007, 09:00 AM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Valve spring retainers
Can anyone recommend a retainer? 624 head 350 Chevy with 1.220 springs in a stocker with 400 lbs. over the nose. Are the Chevy HP Z/28 retainers sufficient for this task?
Thanks,
Joe Marcinowski
3377 I/SA
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 06-16-2007, 11:26 PM   #2
LILWJ
Guest
Posts: n/a
Default
Joe, i have used a lot of them wirh that much spring pressure with no failure on roller cams. but if you are using flat tappet, i am not sure about using them, i would think they would be ok, but i've not had that much pressure on one of those type cams, almost but not quite.
woodro josey
I miss Buster Couch and Lex Dudas.
Old 06-18-2007, 05:33 PM   #3
Joe Marcinowski
Default
Woodro, Thank you for the reply. I will be using a flat lifter. I will also probably end up close to 400 but not quite, I was just being general. I have the Z/28 retainers, I am just wondering if there is a better alternative.
Thanks, Joe
Old 06-18-2007, 08:43 PM   #4
LILWJ
Guest
Posts: n/a
Default
GM retainer is the litest!
woodro josey
Old 06-19-2007, 08:23 PM   #5
Bub Whitaker
Default
Use the retainer off the Vortec heads.. Lite and shorter installed height. or LT1 ...lightest
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 06-20-2007, 06:07 PM   #6
Joe Marcinowski
Default
Thank you guys for the response. I was aware of the light weight, I just wasn't sure if the GM retainers could handle the load of a stocker engine. If Woodro Josey and Bub Whitaker both say to use the GM retainers, I guess nothing more needs to be said.
Later, Joe
Old 06-20-2007, 08:35 PM   #7
Bub Whitaker
Default
Hey woodro ... you got top billing on this one... but you are my elder!
Bub Whitaker
Old 06-20-2007, 09:45 PM   #8
LILWJ
Guest
Posts: n/a
Default
Bub, but only by a few days,,,,,,,,,lol
woodro josey
