Old 06-05-2007, 03:34 PM   #1
Brian Holcombe
Default Single wheelie bars
I'm thinking about building some Single Wheelie bars for stockers, Similar to Biondo and the 72' chevelle Abbazia/Landolfi ride.
If anyone is interested, email me at Speedygoomba@yahoo.com
Brian Holcombe is offline   Reply With Quote
Old 06-06-2007, 04:39 PM   #2
Jim Kaekel
Liked 536 Times in 110 Posts
Default
Not to detract from your post, but why would someone want a single wheelie bar as opposed to traditional double wheel? A friend of mine almost destroyed his Camaro Super Stocker several years back when he launched into a huge wheelie, pivoted over on the single wheelie bar and almost flipped over.
Jim Kaekel 3836
Jim Kaekel 3836 STK
Old 06-07-2007, 09:47 AM   #3
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Default
It's a matter of taste and function. I personally love the single wheelie bar. We initially hung a typical super stock wheelie bar (solid mounted to axle) on the back of my A/S car and the first time I dumped the clutch it unloaded the rear and blew the tires off the car. A lot of guys bandaid this by bending the bars up and getting nasty with the rear valence. I didn't want to do this so I build a singe bar setup with with the mechanics similiar to AJE's bars.
http://www.ajeracing.com/wheeliebars.php
Rear axle seperation and pinion climb does not affect the bar which means now I can run it nice and low similiar to a chassis car and use it as a tunning tool. I did order a spring kit for it but the stock spring is only approx 240 lbs/in. After some online searching I found one that is 560 lbs/in which works perfect on my car. If the air and track are killer I just screw preload in it to stiffen the bar and can lower it to get it working sooner.
Here's a video with great air and the bar pretty high. The starting line prep and having the Cal-Tracs adjusted correctly has determined for me how straight the car went, not the bar.
http://vids.myspace.com/index.cfm?**...eoid=824468153
Troy Henderson
5118
A/S
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is online now   Reply With Quote
Old 06-07-2007, 12:27 PM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Default
Troy - do you have any pics of how it's attached?
"The future isn't what it used to be."
Bruce Fulper is offline   Reply With Quote
Old 06-07-2007, 04:51 PM   #5
Chris Hill
Liked 244 Times in 26 Posts
Default
Just a warning for wheelie bars, specifically the AJE bars.
Don't come out on kill and try the bars out for the first time. Dad almost flipped over first time out with the AJE bars in T/Stk trim. Got way too high and had to lift. Luckily not too much was hurt that time. Got a nice shot of the car on one wheel after he lifted...
Chris Hill
Spec 125 Light
Chris Hill
Old 06-07-2007, 05:40 PM   #6
bob gonier
Default
I wish I need wheelie bars Brian [:-grin-:]
bob
bob gonier is offline   Reply With Quote
Old 06-07-2007, 06:24 PM   #7
Brian Holcombe
Default
LOL thanks bob!
Thanks guys, ethier way i feel that the Single wheelie bar has worked well on the car i used it on, and i'm glad to hear alot of others have had positive results with them.
One big plus is that they're lighter then a regular setup.
Old 06-08-2007, 08:56 AM   #8
Troy Henderson
Default
Send me your email and I'll send a couple pics when I get a chance.
Troy
Troy Henderson
5118
A/S
Troy Henderson
Old 06-08-2007, 11:09 PM   #9
Brian Holcombe
Default
thanks!
Old 06-09-2007, 02:37 AM   #10
Bruce Fulper
Default
pics -
indywinner@dslextreme.com
