How much horsepower to take a 3600-3700 race weight car the following times with a TH400 trans ?
11.50 10.90 10.50 10.00 Say a Camaro, Chevelle, Mustang etc at that weight Figure small blocks that dont have a ton of torque For you stick guys out there, how much hp to go that fast with a 4 speed at that weight ? |
Liked 166 Times in 46 Posts
Need about 450 hp to run 11.50 and about 750 hp to run 10 flat with an automatic in a 3700 lb. car.
I have the calculator somewhere in this box, but for now here is a link that has a lot of calculation formulas, hope they help someone, Henry.
http://www.csgnetwork.com/automotiveconverters.html
old 1608 stock racer |
Liked 165 Times in 59 Posts
How much HP would a 3650 chevelle have at the engine as a guess with the following ET's and driveline
3650 chevelle race weight 327 small block Spun hard so we leave from an idle and spins hard from an idle just not as bad,, anyways here is some ET info 60' 1.765 (spun through low gear) 1/8 7.49 @94.93mph 1/4 11.645 @118.98mph but lifted before lights Next best pass which was a little too wild (which we think was the track) 60' 1.62 (leaving 3600rpm off t-brake and 35-40' out went to the left out of groove and had to be pulled in) 1/4 11.70 @117.56mph (on and off throttle 3 times, last was lifted car length or so before lights) I need to figure out the suspension and the walking in the groove,,,, our other car walked in the groove too but with a 32x14.5W it felt fine. The Chevelle on 8.6" tread is not fun Im looking at maybe putting a radial on it,, How will a radial hook leaving off the transbrake ? Any tricks to radials ? I see alot of race cars going to Mickey Thompson ET Street Radials on 100% drag cars, i watched a mustand go 1.28 60' on a pair of 275/60 15's Here is a video of the 11.645 @118.98mph pass http://s510.photobucket.com/albums/s...t=MVI_0362.flv Thoughts ? |
To start with, you need a new camera man!
Jeff Lee 7494 D/S '70 AMX |
