Old 04-07-2009, 12:53 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Best 15 inch trailer tires currently are?
Its for a 24 foot enclosed. Currently has Titan C rated 205 75 15's which are decent enough, but you can only go 50 lb's in them.
What I have found in my area(Ma)
Towmaster....at VIP
Carlysle.....D rated, still on a container en route
Any suggestions from those who tow on the smaller scale?
Thanks
Eric
Eric Merryfield 1883 STK
Old 04-07-2009, 01:16 PM   #2
bobby
bobby's Avatar
Default Re: Best 15 inch trailer tires currently are?
Carlisle is a good brand. I always went to Discount Tire and bought the cheapest I could afford and the road hazard also.But then again, I never towed a heavy weight with it either.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 04-07-2009, 01:51 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
All 15 ST trailer tires are made offshore. I have had blow outs with Carlysle and Titan. I also had Michelins when they made a 15" trailer service tire and that was easily the best. I have Goodyears now after I blew out a Titan......the Goodyears are made in China...so were the Titans....and the Carlysles were junk......There is no clear choice as they all have failures. They need to be replaced after 2 or 3 years, inflated properly and inspected regularly for tread issues. The Carlysles had treads seperating after a couple years. The Titans were E rated and one blew out on a cool evening after just a few miles on the intrerstate so heat was not much of a factor and they were fully inflated......16" LT tires is the way to go.......
Rich Biebel
S/C 1479
Stock 147R
Old 04-07-2009, 02:23 PM   #4
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I would agree with the 16's. I kept poking around, for a couple months. I bought some 16 wheels at Southwestwheel, just gray with holes, nothing exotic( $40 ea), and then I got a set of Ironman 215/85/16's These are 10 ply and they ride so much better and stable than the 15s. I put 80-85 lbs and they have made the trip to La., and back almost 1400 miles and they are still perfect. No a single lb down yet. They are 1- 1/2 " taller than the 15's I took off. Thats it. They fit good. If you gonna buy tires, buy that. Tires were just over $100 ea., here, locally. I dont have a clue where they are made or who actually makes them though. Right now, I really dont care.
2894 STK
Old 04-07-2009, 02:32 PM   #5
Eric Merryfield
Thanks. The size is a big help. Did you notice if your gas consumption changed with the lower rolling resistance due to higher air pressure, yet more drag(higher trailer)?
Old 04-07-2009, 02:41 PM   #6
Jeff Teuton
Liked 325 Times in 50 Posts
There are no good 15" trailer tires. Do yourself a favor. I assume you have 6 hole wheels. Get some 6 hole 16" wheels ( aluminums are about 80 unless you find some blems). 16" 10 ply (load range E), run them at least 60 lbs and forget your troubles. Most wheels are 16 X 7, or you can get premium Am Racing 16 X 8 Polished for a good bit more. I have blown too many tires to talk about. And any tire marked trailer special run away from. They are the king of junk.
Jeff Teuton 4022 STK
Old 04-07-2009, 02:29 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Best 15 inch trailer tires currently are?
I had trouble with Carlisle C and D rated tires not lasting on a heavy OPEN trailer! There have been a few discussions over the years on different forums where the majority of posters agreed that Carlisle was junk.
I have friends who own a tire store sell me Towmasters and/or some other brands with good results. I don't remember more details since I started using an enclosed trailer with 6,000lb axles and 16" tires a few years ago. But I would stay with at least a D rating regardless of brand.
LOCOMOTION Racing
