Liked 136 Times in 49 Posts
Any one out there towing with or have experiance towing with a van? I am looking at a 2006 chevy 3/4 ton van with the duramax and allison. I tow a 22 foot inclosed trailer with a 3400 pound car and the needed goodies.
I know a truck would be better but I need some thing with a wheelchair lift. Thanks John |
#2 | |
Liked 4 Times in 4 Posts
Two things: get a good hitch, preferably an equalizer and get good HD tires. Jim R |
An old friend (Gary Ericksen) towed for years with an old Ford 3/4 ton van. His was a model without a lot of overhang over the rear axle, so it handled the towing very well. I once towed an electric race car on my trailer with a 9-passenger E350 van (lots of axle overhang) and it was a little unnerving in bumpy &/or windy conditions.
Regards,
Michael Pliska 643 S/G |
Liked 33 Times in 17 Posts
Longbob,
Personally, I would stick with the white camper shell since the truck is white. To me, it just looks a lot better when the truck and shell match but that is only my opinion. |
Liked 6 Times in 3 Posts
Hey NovaSS Dude, I'm with LongBob on this Duramax/Allison combo. I recall GM offering the toned down version of the Duramax (lower hp and torque) in a 3/4 van but it had the 4L80E tranny or something equivalent.
Check out the van and let us know if it is actually has the Allison tranny. I'd be interested in having a van if you could get the Allison in it. |
Liked 317 Times in 103 Posts
I towed my wagon on an open trailer for ten years. It was a Dodge 1/2 ton with a 318 and towed just great. I put all my tools and such in the wagon, while I had my bicycle and full size matress along with other support equipment in the van. When I got to the track everything was unloaded and put under the trailer for rain protection. The matress fit perfectly between the wheel wells. Only problem is on hot humid nights you would need the windows open, but that would let in the mosquitos. Cold nights, no problem, more blankets. You have to park somewhat close to the port a johns for early morning dumpings.
In Atlanta, the wife and I would go to the truck stop down the road for showers. Everything was going along fine until the wife said at Atlanta several years ago, "That is, it no more van for me, either get a motorhome or go to the races by yourself." Well, I got an old motorhome, fixed it up some and had a great time since. Unfortunately, now it is not economical sensible as it gets horendous mileage, but it is still great for short trips. But a van is very feasible. Hope this helps. By the way, with a van and an open trailer you get some great pit spots as you require very little room. Ron Ortiz U/SA
Ron Ortiz 2102 STK |
Thanks for the information. I will double check that it is the Allison transmission. A motor home would be great but it is just not in the cards right now.
Liked 30 Times in 5 Posts
You would need radial 10 ply tires on the rear (range E), a Reese type torsion bar & sway control.
For suspension, you should put in air bags with 30 lbs. air for stabilization. You should be able to go and not have any problems. I've towed this way for 14 years without a problem. My van was a '85 Chevy Diesel (3/4 ton) with a stick shift. Joe Greek |
Thanks guy's I did some checking and it has the 4L85E I believe is what they said. Any one have any experence with this tranny behind a diesel? Or experience with the toned down version of the deramax?
Banned
If you are puting tires on put 12ply on rear and and 2" wheel spacers (H&R makes a very high quality steel spacer that uses stock lug nuts) this will get the rear treadm with close to the from in production close to 5" narrower than front.
QUOTE=Joe Greek;115685]You would need radial 10 ply tires on the rear (range E), a Reese type torsion bar & sway control. For suspension, you should put in air bags with 30 lbs. air for stabilization. You should be able to go and not have any problems. I've towed this way for 14 years without a problem. My van was a '85 Chevy Diesel (3/4 ton) with a stick shift. Joe Greek[/QUOTE] |
