Liked 2 Times in 2 Posts
Dont know WTF whats so different about my car.3K lb Duster mild 440/727/456 Runs low 7,s 1/8 1.53-1.55 60ft
Yesterday dropping my launch RPM down to 1800,staging as shallow as possible.Making sure I see the bottom yellow.Still .018 red.Getting frustrating.(I was dead on with a 6 after the redlight) I cant stare at the bottom yellow all day.Thats just way to inconsistent. So heres my choces I have come up with so far to slow the little Dusters R/T,s The cheapest and most suggested fix Simply leave in 2nd gear! I dont really like this cause it will slow the cars E.T. down . Put a taller tire on the front.I have 25" hoosiers thats the tallest that will clear the Hooker fenderwells. Go to a powerglide to get rid of that 727 2.45 1st gear ratio.Would love to,But too expensive right now. And my latest thought Swap the 4.56 for a 3.91 I know I am probably doing ths the wrong way but heres some simple math of adding trans first gear ratios and rear gears ratios to come up with a final number. 1. Leaving in first with 4.56 = 7.01 2. Leaving in 2nd with 4.56 = 6.01 3. Powerglide with 1.76 low gear and 4.56 = 6.32 (I think this is where I want to be) 4. Leaving in first with 727 (2.45 low gear) and 3.91 rearend = 6.36 5. Same as above with 4.30 rearend = 6.75 Notice how close #3 and #4 are. A R&P set only about 200 bucks.I might lose a little E.T but should pick up a little MPH. So am I on the right track here? |
Taller front tire will put you right there
Man I wished I could.This winter I bought a new set of Hooker fenderwells because I was told they could be re-done to fit a 26" tire.After I paid the guy still could only fit a 25" without beating up a couple of tubes which he refused to do.Think I would have to go to a 28" to help.They just aint gonna fit on this car
A couple suggestions.....not knowing all the details.....a couple lbs. out of the front tires could give you all you need if you have the pressure up pretty high....if the front still has the stock control arms and you still have the upper rubber bump stops in place you can trim them down,this will give you more travel (more time) before the front tires pull the beams.....you can also lower your torsion bars a little(gives you a little more travel) before the tires pull the beams, this will probably require an alignment to put the front end back in spec, but these are all cheaper than replacing gears, I have used all these individually or in combination to dial a reaction time in depending on the track conditions.....
Have you tried " blocking", or a 5 tenths pro tree to see where you're really at?
I have trimmed maybe half of the rubber stoppers off.Think I will just take them out.Sat I had 27lbs air in front.Can I safely go down to 20? Mark What if i cant get a light on a .5 pro tree Does that tell me I'm anticipating and leaving with the bottom yellow? Sure doesnt seem like it.Am going to T&T Wed to try a couple things.-----But still--will going from 4:56 to 3:91 slow down the cars R/T? with everything else being the same? I have a new converter here I just got (BTE) Havent had time to swap it out.Will a looser converter slow down R/T?
