Old 06-18-2009, 09:15 PM   #1
kingsransomracing
Default Alf weibe Suspension
I have read there are 4 iterations of this suspension, can anyone PM me the differences in the iterations?
kingsransomracing is offline   Reply With Quote
Old 06-19-2009, 06:40 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Alf weibe Suspension
Mike, why not ask the guy that made the statement a few years ago, the same guy that's been running this suspension for the past 9 years, the same guy that has made far more passes with it than anyone else and the same guy/the only guy according to Alf that has gone a best of 1.28 60 foot @ 3880lbs. with it, powered by his stout pump gas oval port headed 468...
http://s117.photobucket.com/albums/o...current=10.flv
and who last year went 1.36 60 foot with the back tires with his new engine on a restrictor plate....
same guy that has tried to help you for years!
Old 06-19-2009, 08:21 AM   #3
kingsransomracing
Ed....you are the person I know would know the differences between the 4 versions and I am glad you responded because you were the person I wanted to ask. I have an old email address of yours and it didn't work, so I was hoping that you would be around one of these forums. So can you email / PM describing the different versions?
Old 06-19-2009, 08:31 AM   #4
1320racer
1320racer's Avatar
Mike, version 1/the original and version 2 are the same except with the addition of gussets and a sleeve incorporated after I broke/bent the passenger side arm.
Version 3 is not legal for stock eliminator and the one I had been running for the past ~5 years
Version 4 is the latest, developed a few years ago and the one that Alf is selling to stock eliminator racers now as a result of the issue with Kevin Borgstrom's car last year in Division 5.
Old 06-19-2009, 02:26 PM   #5
kingsransomracing
I heard that the "x-pattern" looking lower control arm, was switched to more of a "V" (the round bar meeting up with the square tubing at the front lower mounting point? Is this true?
I believe the one I have is "Version 3" since it has all the gussets, andalso has all the adjustments available on the upper (relocating bar) and the lower bar to adjust square / pinion angle / wheelbase.
Old 06-19-2009, 02:36 PM   #6
1320racer
1320racer's Avatar
If your lower arms are an X you have version 2.
Version 3 and 4 are V but the forward attachment point is not the same.
Old 06-19-2009, 03:42 PM   #7
kingsransomracing
Ed...Check your PM
Old 06-29-2009, 11:40 PM   #8
Philip Baise
Talking Re: Alf weibe Suspension
Does anyone have a web site to go to about Alfs setup.
Philip Baise is offline   Reply With Quote
Old 06-30-2009, 03:36 AM   #9
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I don't believe he has a web site.......
