Old 08-02-2009, 09:56 PM   #1
Kingpen
Liked 64 Times in 22 Posts
Default 12 Bolt Chevy problem
Ive been fighting a problem with keeping pinion shims from coming apart & out.car is a 95 camaro stocker but I run it in SS with SS motor.weighs 3400lbs with p/g & 99% of the time it is foot braked.it has a Strange housing ,which I figured would be better for making things last longer,but after 50-60 runs,it will start making noise & when I check,the shim is gone.this has happened 3 times in the last 2 years.I use the ratech collar instead of crush sleeve and always get pinion depth within .003-.004 of what is written on gear.Pinion nut is still "tight" from the loctite but of course has some slack from the lack of shim.The nut backing off doesnt seem to be the trouble as I have marked it before to see if that was the case.any ideas,suggestions(dont want to change housings),something I am missing???got lucky this time and didnt hurt gears,not so in the past....let me know............thanks Vic Penrod
Kingpen is offline   Reply With Quote
Old 08-02-2009, 10:38 PM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: 12 Bolt Chevy problem
Vic what rear end cover are you using? Not sure if its the problem or not but you should use a cover like the one T/A sells. Moser does also (think T/A makes them for them). Ive heard stories about the 12 bolts where the main caps actually "flex" on the launch. Maybe its flexing causing things to beat around in the pinion?????just a guess, something worth looking at maybe.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 08-03-2009, 01:04 AM   #3
I don't know what's causing the problem, but why don't you put a shim under the bearing race, like on a Dana?
Old 08-03-2009, 03:28 AM   #4
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Thats what I do in my 12 Bolt
Bob Bender 144 O/SA
Old 08-03-2009, 06:20 AM   #5
Liked 1,927 Times in 433 Posts
Never had a good pinion shim fail, unless the pinion nut is backing off, or not tight enough to begin with. It is also possible that the bearings are not getting enough preload. Ordinarily, it will kill the shims on the spacer before it hurts the shim on the pinion bearing.
Old 08-03-2009, 06:42 AM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
You're not honing the forward pinion bearing to make it easier to set up the pinion depth??
Are you???
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-03-2009, 06:19 AM   #7
Danny Ashley
Liked 110 Times in 29 Posts
Sounds like not enough pre-load on the pinion. How much do have on inital set-up? I've always set mine 15-17 inch pounds. I see where Ratech now has a "Smart Sleeve" that you may want to try instead of the solid spacer. Good luck. Danny
Danny Ashley is offline   Reply With Quote
Old 08-03-2009, 08:24 AM   #8
Jim Kaekel
Liked 536 Times in 110 Posts
Mark is correct. I had similar problems years ago with mine, shims getting damaged, but the Ratech severe duty pinion shim kit #1901 solved the problem. Kit relocates shims between the housing and the race.
Jim Kaekel 3836 STK
Old 08-03-2009, 09:22 AM   #9
Ed Wright
Ed Wright's Avatar
Guess I have been lucky. I've never had that happen. I think you need to get closer with your pinion depth, but that won't effect the shim problem. I have broken teeth on one ring gear, and found them cracked on another a few weeks back, but my shims have always lived. That's a new one for me.
Ed Wright 4156 SS/JA
Old 08-03-2009, 10:05 PM   #10
Kingpen
some really good points that you sometimes overlook because you get tired of looking..yes I have a good cover/girdle,but yes I am also guilty of sanding the pinion gear for easier removal.my other car has a dana 60 that has all that stuff & never had problems ,but shim is also behind the race too.I will try that with the 12-bolt & see.as far as pre-load,Ive never measured it,just went by feel,and have used from "snug" to "tight",,I probably should actually measure it....as far as the pinion to bearing fit,I have some Green sleeve retaining loctite,will this help,plus maybe some carefully placed light center punches work to hold it in place?..I really appreciate all the answers & suggestions,if there are any more,I'll gladley listen as it will still be a couple of days before i start back toegther with it...........Thanks so much,Vic.......P.S. I also have some converter questions I'll ask in another thread if anyone wants to help
