Can someone help me to understand how to read the classification guide? To determine the weight break, do I look at the year of the car with the size of the intended engine in the same year?
My intended combo is for Super Stock.
Ronnie Dozier |
Based on the Classification, a 3 door `982 Mustang has a shipping weight of anywhere from 2,555 to 2,582 (depending on base model, GT, GLX or GL body). There are two, 1968 Ford 302's listed. One is a 210 HP NHRA rated, one is a 230 HP NHRA (de-rated to 200 with OEM heads or 230 with Replacement Heads). Using the 210 version, in the GLX body, the weight break is 12.29, making it a natural GT/I or GT/IA, and is permitted to also run GT/H(A) and GT/J(A).
http://www.nhra.net/tech_specs/class...s/1968FORD.xls http://www.nhra.net/tech_specs/class...s/1982FORD.xls
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
Mike: thanks for the explanation.
One other question, how do I determine which HP rated 302 I would be using?
Ronnie Dozier Last edited by Bruno 3776; 02-20-2010 at 04:17 PM. |
210 hp is a 2 bbl. combination
230 hp is the 4 bbl.
Dave Ley NHRA TECH |
So if my heads show the casting of 2V - C8OE-J and based off of the NHRA blueprint guide, these are for the 210 HP combination. I'm assuming that means I couldn't use them on a 4 bbl 230 HP combination, correct?
Mike also pointed out that the 230 HP combination is with "replacement heads" and defactored with a OEM heads. I don't see a specific replacement head listed for the 1968 302. Any ideas about how to find out what that replacement head is?
Ronnie Dozier |
All the information you need is in the Classification Guide and the Engine Blueprint lists. If you look at the top of the 68 Ford Class Guide ( GT Specs) it shows the different HP ratings for the different heads. When you go to the specific car in the Class Guide ( 68Mustang ) it shows the replacement heads. In your case Canfield or AFR. Now if you are really serious about this combo you can claim it as a 68 Mercury 302 and you get to use a Holley carb.
