Old 04-09-2010, 12:35 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question work car oil input wanted
Ok guys I got myself a "new" work car (new to me that is) it's an 07 Chrysler Sebring with a 2.4L it only has 18,000 miles on it. What I want is you guys opp on what oil weight? calls for 5W20 ??? or should I go with 5W30?? I checked the gas mileage today it got just over 31 MPG witch I think is pretty good. Thanks for the input guys
Old 04-09-2010, 12:47 AM   #2
GTX JOHN
Default Re: work car oil input wanted
I have been a long time fan of Mobil One....most of my new stuff calls for 5-20 so I use it...have not had any problems. Even use it in my bracket cars because it is 1/3 price of Royal Purple.
John Irving
Old 04-09-2010, 01:05 AM   #3
greg fulk
greg fulk's Avatar
Thumbs up Re: work car oil input wanted
thanks John. That's what I run too. So no big deal between 5W20 & 5W30. The only reason I ask was I've run 5W30 in everything for so many years....
Old 04-09-2010, 04:25 AM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i don't think your sebring has variable valve timing so it's not gonna be a big deal to use either BUT i'd run the weight that's recomended.
you can't go wrong with just about any synthetic...
but i won't use pennzoil in anything...syn or dino...esp in vw's...they've already got sludge problems
Old 04-09-2010, 10:12 AM   #5
63corvette
Liked 359 Times in 103 Posts
Pennzoil and Quaker State is the same oil and same company and both have sludge issues.
Its the base stock they use according to a good friend who is a oil sales rep.
I had sludge issues with it years ago and stopped using it.
My brother in law had oil pressure issues with his 05 Chevy PU after using Pennzoil in his 60,000 mile vehicle. Upon pulling the pan it had an inch or more of sludge and restricting the oil pickup. Changed the oil pickup and cleaned the pan. Oil Pressure Problem Solved.
He is now using Valvoline and changing it at 1,000 mile intervals to try and clean up the rest of the oiling system.
My 2 Cents
63corvette is offline   Reply With Quote
Old 04-09-2010, 11:19 AM   #6
greg fulk
greg fulk's Avatar
Red face Re: work car oil input wanted
It has the variable valve timing?
Old 04-11-2010, 11:48 AM   #7
John Boland
Liked 2 Times in 2 Posts
You are right about Pennzoil and Quaker State being the same company, along with Slick 50 they are now owned by Shell. Your sludging issue years ago was probably when they were both parrafin based Pennsylvania oils. They were famous for that. (Caker State, LOL) However I am told that with modern oils, the base stock doesn't matter as much, it's the additive package that makes the oil.
A family friend was a Pennzoil engineer until they turned out the last light in PA. He believes in cheap oil and frequent changes. He says the extended intervals are the car manufacturer's idea and not the oil companies. He says the dirt is still in there and the oil is engineered to keep it suspended. I believe that but I have been using Mobil 1. Every 7500 miles for 11 years now. I would have to change my oil every 5-6 weeks if I use a 3000 mile interval.
Your brother in law's sludging problem raises a few questions but hopefully he gets that worked out.
QUOTE=63corvette;180982]Pennzoil and Quaker State is the same oil and same company and both have sludge issues.
My 2 Cents[/QUOTE]
John Boland is offline   Reply With Quote
