I hate coil springs..............
Trying to get ride height correct on my 67 Firebird convt. I have a aluminum headed SBC in it - crate legal IHRA stocker. I need to drop the front end about 1.5 - 2". I have Moroso #47150-110 springs on it, uncut. Car weighs about 3450 w driver, at natural class. How much do I need to cut? Also, should I cut the top or bottom of the spring, or does it matter? I always cut the top before, but never hurts to ask. Have not cut any in several years. Also, the springs have been on several months and have 25-30 passes on them now... should have settled by now. I really want to get this right the first time, as I hate taking then in and out! Thanks in advance! Ken |
Liked 55 Times in 28 Posts
Check the upper (frame) pocket. If like 64-7 A bodies, it is formed for the tangential spring end and the tail has to fit to the end of the pocket. This limits how much you can cut off the coils, because the bottom (A frame) pocket also wants the end of the coil in a specific place--between the two indicator holes. Generally, you are best with an integral number of coils plus 2 to 2.5" more on one end. It might be too much, but on my A body, Moog 5230 with 3/8 coil cut from each end works.
Thanks.
Mine has a coil seat with a stop on the bottom, but the top pocket is flat all the way around. Does not make a difference on the top. So, we cut on the top of the spring. Big question is still how much to cut? thanks all, Ken |
If the top perch is flat and not formed for a spring end, then you should start with the 68-72 style spring that has a square or flattened top end. It is tough to give a recommendation because front end weight, desired ride height, and spring rate all affect the needed spring height. For a 250 lb/in coil you will probably want it 17-18" free length.
Liked 99 Times in 60 Posts
Ken,
you will not what to hear this ![]() There is just no way to know, it is cut and check deal. I would begin with cutting 1/2 coil and put it back together. I does not matter which end you cut as far as spring performance goes. Cut the end that will best fit the spring seat after it is cut.
Larry Woodfin 471W |
Liked 56 Times in 27 Posts
Ken,
Start by cutting a 1/2 to 3/4 's of a coil off, as Larry said .... Don't use a torch, try a sawsall , much neater & less heat... They are much easier to replace with the engine in the car ??? Good Luck & e-mail me if you have anymore questions .......
Dave Ribeiro 1033 STK |
