Old 01-30-2012, 01:21 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Question Blowing oil out of trans?
A friend of mine has a SBC stocker and recently experienced a problem. He made several passes with no problems. But on his last pass once he crossed the finish line and got out of it it started pooring smoke out. He saw it, cut it off and coasted off the track. When I got to him he showed me where the dip stick was pushed out and trans oil was everywhere!. It is a T200 with a breather tube on the firewall and a locking dipstick. He just loaded it up and went home. The trans seamed to work ok after that. What could cause this? The trans is not brand new but not wore out. Any ideas? Thanks
Robert Simpson is offline   Reply With Quote
Old 01-30-2012, 01:27 PM   #2
SSGN
SSGN's Avatar
Liked 197 Times in 52 Posts
Lightbulb Re: Blowing oil out of trans?
Does the breather tube go to a catch can?? All of my 200r4 do this when hot,so I built a nice catch can with a drain ****
Kevin
Old 01-30-2012, 01:52 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Blowing oil out of trans?
I run a m200 in my stocker, heard of that happening. Seeing it never did it before I would pull the pan and have a look. You say it pushed out the locking dipstick, did you just install it. The orig. one has a v in the upper seal which helps in venting. gsa612
Old 01-30-2012, 01:59 PM   #4
Liked 1,914 Times in 429 Posts
Does he know what his transmission fluid temperature is?
If it pushed a locking dip stick out of the tube, the vent system is stopped up somewhere.
In any event, that much pressure is a sure sign of a fair amount of heat.
Old 01-30-2012, 02:06 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Blowing oil out of trans?
You beat me to it Alan! Younger brain and fingers! Jim
Old 01-30-2012, 04:41 PM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
X2 on what Alan said. High fluid temps, over full condition, plugged vent or an internal hydraulic oil pressure leak can cause this as well. It's best to fill race transmissions to the 1 pint below full mark if the dipstick is labeled as such. Hope this helps, just my .02.
Jim Kaekel 3836 STK
Old 01-30-2012, 05:30 PM   #7
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Blowing oil out of trans?
I still agree with having an over -flow bottle for M-200 ... Also agree
with running it a pt. low to start ...Check the dipstick & tube for cracks. Agree with Alan on fluid temp ? Make sure you check level after a few passes , if its low for a while it will start to flash higher in the 1-2 & 2-3 shifts .... Good Luck ,
Dave Ribeiro 1033 STK
