Old 02-24-2012, 10:05 AM   #1
bert powell
Liked 34 Times in 12 Posts
Default Fuel pressure running off at the worst time
Guys, been aggravated with this problem on and off for a while. I have a GT/CA Camaro with a Qjet, Magnafuel 500 pump and the large 2 port reg. I added a fuel guage at the pump and was getting 26 psi at 12v. When I switch to 16v it would peg the guage over 30psi. So I tried to reduce the pressure and when it did come down the pump bypass would leak because it was screwed out too much. I cut two coils off the bypass spring and got the pressure at 26 psi at 16v. Reset the front regulator at 6 psi and went to test. First run fine. Second run, after the burnout the front pressure went to 12+psi. Got back to pit and cycled the pump, sat there at 6psi and would not move. Going to check the regulator for trash again but did not find any before.
Anyone used the Magnafuel large 2 port regulator before without issues? Thinking about changing it.
How much can I lower the pump pressure and still be safe, thinking about dropping it to 18psi.
I had a carb fire trying to get the thing down the track before and would like to fix this permanently. Any ideas?
bert powell is offline   Reply With Quote
Old 02-24-2012, 10:31 AM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Fuel pressure running off at the worst time
After installing my Magnafuel system I was having a problem with the large port regulator as well. Out of the blue the pressure would spike pegging my guage and of course blowing the needle and seat off the q-jet. I contacted magnafuel and they suggested along with the rear fuel filter to add an inline filter just before the regulator. Since I have done that never an issue again. They claim that the regulators are very sensative and the smallest particle of anything can cause the regulator not to work properly.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 08-12-2013, 10:14 AM   #3
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Bob - I'm having the same problem and will be adding a filter before the regulator. It happened when I was trying to start the car Thursday night to load up for Cedar Falls...filled # 7 cylinder with fuel, along with the crankcase. What filter did you use? Is it a finer mesh than the one at the rear of the car? Thanks.
Paul Merolla is offline   Reply With Quote
Old 08-12-2013, 10:37 AM   #4
Bob Gullett
http://www.summitracing.com/parts/mrf-mp-7010
http://www.summitracing.com/parts/mrf-mp-3013
This is the filter and fittings I use and Magnafuel recommends. I would recommend after installing it run the pump for a few seconds with the line from the carb removed into a container to flush anything out.
68 Chevy11 327 F/S
Old 08-13-2013, 07:21 AM   #5
Paul Merolla
Thanks, Bob.
Old 08-13-2013, 09:28 AM   #6
bert powell
Funny this has come to the top again! Adding the fuel filter before the reg fixed the original problem for me! I try to clean the reg regularly.
Just this past weekend I was going to load the car in the trailer and the fuel pressure was good before starting -7psi. When running it would drop down slowly to 3psi and then go to zero. Cleaned the reg and tried another carb, same thing. Going to check the pump next.
Been wanting to switch to a bypass reg, this may be the time...
Old 02-24-2012, 10:35 AM   #7
philbilly
philbilly's Avatar
Bert I would check the reg. out not to mention I would check the bypass valve on the pump for some foreign object. If it held steady like your post then just out of the blue jumped up like that it is probably in your reg.
philbilly is offline   Reply With Quote
Old 02-24-2012, 10:40 AM   #8
Bob Gullett
To add to my post I did have a friend who had the same problem and magnafuel replaced the regulator no charge.
68 Chevy11 327 F/S
Old 02-24-2012, 12:33 PM   #9
Bill Grubbs
Liked 573 Times in 67 Posts
Yes!!! the regulator is very sensitive to contamination. We fought this problem for most of the year last year, new fuel lines, filters, pump wiring, cleaned and serviced pump and regulator. We finally fixed it by adding a MagnaFuel filter just prior to the regulator (huge cudos to Robbie Ward @ MagnaFuel). We now have over 40 passes on the car with no problem.
The filter we added is extremely large so no flow rate or pressur drop is noted. I log pressure to the filter/regulator, and additionally to the carb.
Bill
Bill Grubbs is offline   Reply With Quote
Old 02-25-2012, 10:44 PM   #10
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Hey Bert, long time no see. I run the magnafuel pump and regulator on the mustang with the motorcraft carb. My by-pass pressure with the 16vt system pegs the 30lbs gauge everytime. I never turned it down, figured with the single needle and seat it couldnt hurt sending as much as possible to the front. I use the standard regulator but also use a #10 line (from the cell to the inlet of the carb) and never have had a problem with any of it. Now, because i use C11 fuel, and buy it in the pre package 5 gal pale i dont run a filter in the system anywhere, nor do i have the foam in the cell. 5 years so far so good, course now i jinxed myself and when i put it back together this year ill have a issue lol.... (hope not tho). Talk to you soon bud, good luck..
Lil Duane
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
