Old 03-24-2013, 07:40 PM   #1
Weekend Racer
Default piston deck ss engine
I have an issue with my small block chevy . The piston is .002 over the block on the left cylinder bank and .002 down on the right bank . Is it legal to use a thicker head gasket to correct the piston deck clearence ?
Thank!
Weekend Racer is offline   Reply With Quote
Old 03-24-2013, 07:48 PM   #2
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: piston deck ss engine
Yes. The .004" difference probably would be insignificant otherwise. Next time its down for a rebuild, get the deck heights equalized.
Old 03-24-2013, 08:26 PM   #3
race watcher
Default Re: piston deck ss engine
I am not sure you can run a deck above block. That is the way the rule use to read.
race watcher is offline   Reply With Quote
Old 03-24-2013, 10:34 PM   #4
Jody Lang
Liked 89 Times in 28 Posts
If deck height is suppose to be below deck that's what it has to be. Even when it's suppose to be above block it has to be above.
At least that's the way I remember it.
Jody Lang is offline   Reply With Quote
Old 03-25-2013, 11:22 AM   #5
Greg Reimer 7376
Oops. I didn't remember the legality of that issue. I never had a plus deck engine like that. Better find a way to make it a minus deck engine. If you have rods with the small end bushed, it might be wise to rebush them and offset the pin bore a few thousandths. Otherwise, it's block time again.Best wishes on your project!!
Old 03-25-2013, 11:39 AM   #6
Ed Wright
Ed Wright's Avatar
Since we are talking an SS engine, just deck the pistons.
Ed Wright 4156 SS/JA
