Old 08-14-2013, 06:59 AM   #1
DRAKE VISCOME
Liked 93 Times in 37 Posts
Default need info Corvette
Hey...have 1962 Corvette...327/250-powerglide car...what is correct original cylinder head casting #'s...and original carb...much appreciate some help... Drake
DRAKE VISCOME is offline   Reply With Quote
Old 08-14-2013, 07:50 AM   #2
Liked 1,928 Times in 434 Posts
Default Re: need info Corvette
Go to the link that says "NHRA Competition" near the top of the page. Look at the engine blueprint specification guide, and the stock car classification guide there.
Old 08-14-2013, 10:33 AM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
YOU will like this combination.
The 327/250 has the small Power Pack Heads. (Rectangle with a small Pyramid on top.)
They flow well for very small valves. Think the 520(corrected from FED387 info) is the better head.
You will most likely have a WCFB Carter, some got the Rochester 4GC.
I liked the WCFB better. Cams are small. Not much lift.
Think the xx929 cam was .390 in/ 410 ex. but all the base 327's were around that lift.
The 62 Vette also had the larger valve 340hp and 360hp. Think those cams were bigger.
Then again the NHRA Engine specs have all the goodies.
Ran a 1964 Impala SS 4sp in 1973 in Stock and with 205,000 miles on the odometer AND when Stock was still PURE
Got close to running the national record on cold days.
The engine was easy to tune and run consistently even with a stick.
Car had a Munchie M20 Close Ratio 4sp..Muncie is the correct spelling.
It is a good combination in both Pure Stock and Stock.
NHRA properly factored the 62/62 327/250 engine over the later and more powerful 65 327/250.
May want to consider Pure Stock to avoid adding a Roll Bar and keeping it closer to street worthy.
Dan
Old 08-14-2013, 11:45 AM   #4
FED 387
Liked 336 Times in 183 Posts
1962 Corvette 250/327 Powerglide Trans
OEM carb Carter WCFB 3190S/3788245
OEM heads were 3795896/3884520
Old 08-14-2013, 08:07 PM   #5
DRAKE VISCOME
Hey...thank you all very much for response/info...truly much appreciated!...thank you again,Sincerely, Drake
Old 08-15-2013, 08:05 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Hey Dan,
I had a few Muncies become Munchies or maybe crunchies LOL
Mike Taylor 3601
