Old 11-15-2013, 09:16 AM   #1
HR 9505
Default 3rd generation Camaro rear suspension?
What are you 3rd generation camaro owners doing for the rear suspension? I got a guy who wants me to help him fix a foot brake car out of one. He is looking at 6.90's-7.0's. More than likely use the stock 10 bolt but put good internals. I need rear suspension advice, do we stick with the stock setup with the torque arm and maybe go with moroso trick springs or is it worth it to change it ladder bar w/ coil overs. He does not want to tub it at this time so we will be sticking with a 10" tire.
Thanks,
Jason
HR 9505 is offline   Reply With Quote
Old 11-16-2013, 04:50 PM   #2
Doug Blackley
Doug Blackley's Avatar
Default Re: 3rd generation Camaro rear suspension?
Just an fyi. The stock rear will live for a bit even with good parts but the ring and pinion are the weak links in it. Best money spent is on a better rear. Pete Z bars are an excellent choice. S&W makes a torque arm based set up that works well too
Doug Blackley 1697 STK
Old 11-16-2013, 05:31 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
I had a customer do about the same thing as you with a good crate Mtr. build. The 10 bolt ate 4.56 R&P and internals. Put a spool in it and it still ate R&P, but they lived a little longer. He went to the 10 bolt out of a Buick GN and it has served him well. All the parts in it have more beef.
Adger Smith (Former SS)
Old 11-17-2013, 12:10 PM   #4
HammondRacing
Liked 6 Times in 4 Posts
Does Pete Z Bars have a website ?
HammondRacing is offline   Reply With Quote
Old 11-17-2013, 02:49 PM   #5
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
Pete z atr race cars 315 483-6412
jim powers is offline   Reply With Quote
Old 11-17-2013, 04:07 PM   #6
Shaun Quill
Liked 105 Times in 26 Posts
I used the complete kit from S&W on mine, and it worked flawlessly. Also I bought a real thick rear swaybar from i think BMR,and that really made the car work great-it made the car leave real square. As for the rear, you really dont have much choice other than to put a 12 bolt or a 9 inch in it,its only a matter of time before that 7.5 lets you down. It's a little bit of money i know,but your buddy will have a great working car after he's done and you can do it all yourselves.
