Old 12-07-2013, 10:13 PM   #1
Lonnie Cox
Default EGR Port in the head
Can you block it and will it help performance?
Lonnie Cox is offline   Reply With Quote
Old 12-07-2013, 10:25 PM   #2
Default Re: EGR Port in the head
If you're talking about the exhaust crossover , then go here:
http://classracer.com/classforum/sho...aust+crossover
Old 12-14-2013, 02:42 PM   #3
goinbroke2
Liked 404 Times in 158 Posts
Lonnie, do you mean exh crossover like Mark said or EGR ports?
I take it you are talking the cast-in air injection nozzles in ford exh ports? Since you can't grind them or anything I wouldn't think blocking them would help but I could be wrong. Normally I just put a plug in the back of the head where the transfer tube connects, leaving the internal cast-in passages alone. Here's a picture of a chrome tube still connected;
http://www.supermotors.net/getfile/3...e/xtubenew.jpg
Are you thinking of putting eight tiny plugs in the "nozzles" that protrude into the exh port?
