Liked 52 Times in 17 Posts
Car is a '99 model year but rums as a ’98 with the LT1, with a flat hood that puts it in C,D and E or SS/JA - SS/KA. Change to a ram-air and it fits A,B,C,D,and E. A very versitile combination. Custom ballast weights will move it around a class. It's factory dark blue with tan cloth interior, T-tops, Grant wheel, looks really nice.
RWR, Rick Watters/Tibor Kadar motor. So fresh it’s not even in the car yet ! Hedman headers MSD HSV coil and wires Holley crank trigger MSD distributor Complete Aeromotive fuel system, pump, regulator w/fuel filter and a strainer and nylon braided hoses (not rubber) CSR waterpump with a spare VDO playback Tach Holley annhilitator ignition with spare Holley 950 ECU, datalogging with O2 sensing. My program Moroso circuit breaker switch panel Strong, switchable one wire alternator T-action converter gone through by Munsinger T-action shifter E-Shift installed but not currently used 200 metric trans, auto 1-2 shift, deep alum pan with baffle and extended p/u, prepped by Leo Glassbrenner (Remac) with some of his parts. Also fresh, no runs yet. Fuel cell and rear Optima battery, weight box Strange rear, 4.88 gears with special drum brakes, aluminum drums and soft linings. Lamb front brakes with S10 master, the rod cannot fall out! S&W rear anti-roll bar Chromemoly tubular rear trailing arms QA1 alum. Adjustable shocks front and rear. Spare, steel bodied fronts included Centerline convo-pro MT fronts and radials Aftermarket rack Electric windows with side bars removed from doors New, custom black carpet with filled in floor Roll bar with swing out drivers side bar Several years ago the car was stripped to nothing and put back together that included: painting entire engine bay and underside gloss black then, re-engineer all brackets and plumbing routes. A complete color-coded re-wiring job from front to back with all soldered joints and weather-pak connectors plus much more to make it a really tidy package. Motor and trans are out of the car at present and are been reworked by RWR (lot's of new stuff) and Remac. This car has a long list of praise from many racers ! $31,500.00 with the listed spares Ph. 951 686 4230 bonzaproducts@att.net
Bernie Cunningham 7053 STK Last edited by Bernie Cunningham; 12-11-2013 at 01:41 AM. |
