Old 03-23-2014, 03:02 PM   #1
STR001
Default Looking for rear shocks third gen camaro
Can anybody recommend a good quality rear shock for a stock eliminator third gen camaro? Thanks in advance. Jason
STR001 is offline   Reply With Quote
Old 03-23-2014, 05:11 PM   #2
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Re: Looking for rear shocks third gen camaro
I use Afco Double Adj.
"Pistol" Pete Dutko
Old 03-23-2014, 09:09 PM   #3
Chad Rhodes
Same here
Chad Rhodes 2113 I/SA
Old 03-23-2014, 11:01 PM   #4
STR001
Originally Posted by Chad Rhodes View Post
Same here
So rear coilovers are legal in IHRA stock eliminator class? Did you use the relocation mount for the lower shock mount or use the stud style rear shock? Thanks
Old 03-24-2014, 08:11 AM   #5
Chad Rhodes
They are not coil overs. They are stud mount. I guess they could be coil overs as they have a threaded body. The compression adjuster is on the bottom, extension is on top.
Old 03-24-2014, 10:25 PM   #6
STR001
Thanks for the info. Greatly appreciate it.
Old 04-15-2014, 01:14 PM   #7
STR001
Same here
Chad,
Do you happen to know the part number for the afco rear shocks you used? I see several listed. Thanks, Jason
Old 04-15-2014, 02:51 PM   #8
Chad Rhodes
Chad,
PM sent
Old 04-15-2014, 03:59 PM   #9
KennyAnderson
Liked 370 Times in 122 Posts
Jason I have a budget build 4th gen Camaro we are running IHRA stock with right now and I cant speak for longevity but I have been VERY pleased with the ole three way adjustable Competition Engineering shocks that have been around forever. I set em on 50/50 and was amazed at how good the car works with them. For the $$$$ they are hard to beat.
KennyAnderson is offline   Reply With Quote
