Im gonna put a Lokar dipstick in my Trans... Do i have to have locking type , or just the regular type? Thanks...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 3,232 Times in 983 Posts
Have to have the locking type...been that way for a while now.
Liked 99 Times in 60 Posts
Brent,
I have installed this style on several applications, works great. You can find the part numbers on Lokar web site. "NHRA approved braded locking dipstick kit" The package has everything you need, very good quality, excellent value.
Larry Woodfin 471W |
Liked 536 Times in 110 Posts
Personally, I wouldn't buy the Lokar assembly unless I had to have it. They are harder to fill and read than the OEM dipstick. I have to use the Lokar part because a stock type dipstick assembly won't clear my trans. brace.
If you just need the locking feature, ATI sells a neat Tube Lock #973081. Just check your fluid level using your stock dipstick and put the ATI part when you're done, keeping the dipstick in the trailer.
Jim Kaekel 3836 STK |
I have the Lokar dip stick on my car. The metal transmission funnel & flex tube I got from NAPA several years ago fits just fine if I pull the locking ring down like you would to unlock the dip stick. Hold it in place while filling it, then pull it back to take the end of the flex tube back out. The factory T350 dip stick tube didn't fit my car well. I mounted the flexible Lokar tube on the inner fender.
Ed Wright 4156 SS/JA |
my experience is like Ed's. Lokar has two different versions, the NHRA approved is much easier to fill. The "budget" style has a smaller tube making fluid flow slower.
