Old 05-13-2014, 04:13 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default Pure Stock Valve Spring rule
I am ready to replace the valve springs on My 16000 mile Pure stocker lt1 engine. I am having trouble finding Factory valve springs. Everyone wants to sell me LT4 spring which closed seat pressure is 105. The rules say I have to run 85#@1.78 height . Does any one know of a vendor that has stock lt1 spring? The oem number from GM has been discontinued. Or would the lt4 spring be considered a superseded part for the lt1?
Thanks Aaron
VALVE SPRINGS: Stock replacement per OEM spec. and must check on factory spec. open and closed pressure
russellauto1 is offline   Reply With Quote
Old 05-13-2014, 05:23 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Pure Stock Valve Spring rule
I have a set of stock springs I took off new LT1 heads, when I was racing my Firehawk. They check 85 lbs. @ 1.78" . What is the open spec ? I could bring them to Norwalk. $ 80 . Russ ss3011@aol.com
Old 05-13-2014, 09:24 PM   #3
Ed Wright
Ed Wright's Avatar
You guys might check with TRW. I know it was a long time ago, but when I had my '56 Chevy Jr Stocker we had to have stock valve spring, that had to check correctly. TRW had stock app springs that looked & checked exactly like the GM springs, but lasted longer. My General Kinetics "cheater" cam lobes looked like a roller profile, and was very hard on springs. It was a solid lifter engine that killed GM springs in three races or so. TRW spring would go four to five races.
Might be a viable source.
Ed Wright 4156 SS/JA
Old 05-14-2014, 11:09 AM   #4
gbur
maybe check with K-Motion to see if they have a spring in the required range
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 05-14-2014, 02:37 PM   #5
russellauto1
After hearing from Ed, I checked trws valve spring list and came up with the number for Stock replacment valve spring. I was able to crossover the number to MFGs.
OEM number: 10206040
TRW/Melling Number: VS-2228
Sealed Power: VS-677
Come to find Out the advanced auto parts has 26 of them for 2.95 each .
Thanks Ed Wright For the lead.
Old 05-14-2014, 05:09 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Thanks Aaron
Contact Mike Baker on what Springs are allowed.
Jeff Warren did my Engine and he called Ed to make sure he was installing the correct Spring.
Have the Iron Head LT-1 and he confirmed using Melling VS2228 Springs.
Old 05-14-2014, 08:21 PM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
if they have'nt changed the federal mogul ( sealed power)VS 677 is the closest to spec,I bought new set last year and they were right
Mike Taylor 3601
