Liked 444 Times in 145 Posts
71-72 Small Block Chev motor: 350/270
Carb to pan, includes water pump and ATI balancer - plug it in and you're ready to go. This motor has ten passes on it, .750 under. It has: CP Pistons, Total Seal rings, Chev rods Bushed lifter bores Latest Bullet Cam Comp Cam springs Schubeck lifters Complete Whitaker Valve job - angled milled heads Whitaker Balancing Nice race prepped Quadrajet Electric water pump AtI Balancer New bearings when freshened New roller timing gear set when freshened Your choice of 71 or 72 intake manifolds or you can buy both. They are very clean and legal - been through Indy tear down. $4,500.00 Also have for sale: Fresh, solid shifting, Metric Transmission (forward pattern) by Leon Miranian $1,250.00 Several good metric converters: $400.00 each Two barrel intake manifolds for 71, 72 and 73 Chev 350. They are also very clean, $250.00 each BM Pro Ratchet Shifter: Set up for three speed forward pattern, also have reverse pattern and Powerglide plates as well. Two shift cables. This unit has a lever on it and after ten passes I had had enough. About $600.00 worth of shifter and parts. Now $350.00 Also have a 6,600 Watt Yamaha Generator for sale. New battery for electric start and remote start. Produces 120 and 220 Volts. These units are now selling for $3,000.00+ but will sell this one for $1,250.00. It is in excellent shape and runs very strong. It does have one kink - it will, on occasion, burp a couple of times on a cold start and then take off and run great. I sold my business last fall and now moving to a smaller unit to store my trailer and car. Thanks for reading, Bruce 703.989.4104 shopsilvercloud@aol.com
Bruce Noland 1788 STK |
Bobby L,
I can't respond to your message because you have a blocker on this site. The converters flash between 5,200 - 5,400 with a 400 HP 350 - depending on the air.
Liked 216 Times in 77 Posts
Where are you located? Is this a RV Generator or more like a construction generator? If possible could you send a photo of it to LMLamar70@yahoo.com.
Thanks |
Liked 127 Times in 49 Posts
Bruce,
That's strange I've never blocked this site. I have a 396/350 HP combo so I will probably have to have it tightened up then. How soon are you looking to get rid of it?
Bobby Lundholm 3516 G/SA |
Liked 35 Times in 11 Posts
Bruce ,you have a PM
