Liked 319 Times in 68 Posts
How do you install LT-1 heads on a bow tie block in SS Is welding required or is there a way to do it with a bypass hose? Thanks.
Lee Valentine 1661 STK |
Lee, there are two plugs welded on the deck, oblong shaped. Then the pipe plugs on the front end of each head are drilled and tapped larger for water hoses. I can try to get you pictures of mine if you like.
Ed Wright 4156 SS/JA |
Ed, would like pictures if possible. My e mail 1661stock@gmail .com Thanks.
Sent.
Liked 3 Times in 2 Posts
Hi Ed......Could you send me pics of this also? Thankyou much!
Give me your email. Or I can text it if I had your ph #. Send me a pm.
Get the second picture too?
