Old 04-26-2015, 08:57 AM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default What size fuel line?
For my 396/325 Chevy would a 3/8 - 6AN be good or 1/2 8AN ? Have a 300-400 GPH pump I bought years ago from a retiring Pro Stock truck racer. I used in my 68 Impala with same combination. Can't remember what size line I used.
Will Lamprecht
I/SA 65 Impala in progress
Old 04-26-2015, 09:03 AM   #2
race watcher
Default Re: What size fuel line?
Minimum #8 from pump to front.
race watcher is offline   Reply With Quote
Old 04-26-2015, 09:38 AM   #3
impstocker
impstocker's Avatar
Thanks RW OK 1/2" would 5/8" then be too much?
Will
Old 04-26-2015, 10:14 AM   #4
Lee Valentine
Liked 319 Times in 68 Posts
At least#8 would use#10,with a return system,I've seen something with a Q-jet using a return line.Lee.
Lee Valentine 1661 STK
Old 04-26-2015, 01:19 PM   #5
impstocker
impstocker's Avatar
Thanks Lee- Yes I am going with the #8 and I do run a return line with my pimp. I am a Div 1 NED racers too, hope to see you real soon!
Will Lamprecht
Old 04-26-2015, 03:15 PM   #6
Lee Valentine
Will I keep my race cars in Billings,go through Wingdale often.
Old 04-26-2015, 03:18 PM   #7
Dick Butler
Liked 32 Times in 19 Posts
Note that the return line must be really big to not increase the fuel pressure at the carb. If you find the pressure cannot be decreased to below where you want to run it as a test while idling the pressure is return line resistance..not pump pressure. We used copper gas line 1/2 diameter as return line or pressure at carb too high for Q JET. They seem to like 6.5 to 7 area
