Old 09-02-2015, 01:54 PM   #1
FLEMING
Liked 55 Times in 26 Posts
Default Most reliable ring gear for GM 8.5
What is the most reliable gear for a GM 8.5 at the moment.. Currently have a 4.56 Richmond but heard they have moved everything across the pond.. No one makes a pro gear for an 8.5 so I guess I need the best street gear going right now..
FLEMING is offline   Reply With Quote
Old 09-02-2015, 04:34 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Most reliable ring gear for GM 8.5
Fleming,
what is your application and performance level?
Larry Woodfin 471W
Old 09-02-2015, 05:40 PM   #3
Run to Rund
Liked 55 Times in 28 Posts
Motive of Italy bought Richmond, whose tooling was worn out--at least that is what I heard. I have had good results with Motive gears from Italy. A good set will have no more than .002" runout around the ring through several revolutions so each pinion tooth eventually hits each ring tooth.
Old 09-02-2015, 05:42 PM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Red face Re: Most reliable ring gear for GM 8.5
Fleming,
What ever you get make sure it is made in the USA !!!! The other stuff won't last 10-15 runs !!! Ask for only USA made , don't waste your Time or Money ??? You can tell by the price if there made in the USA , its always more money.... But well worth it, unless you like changing gears every-week ?? Do it right the first time, its always cheaper in the long-run.
Good Luck & be smart ..... Motive, made in Italy/ Germany is an excellent sub for USA made ....
Dave Ribeiro 1033 STK
Old 09-03-2015, 09:33 AM   #5
FLEMING
There is nothing wrong with the richmond that is in it, just want to have a spare to keep with me..
Car is a 1974 nova stocker without stocker motor.. Just has bracket 355 and glide runs 6.90s 1.45 60'
Old 09-03-2015, 10:31 AM   #6
Dragsinger
Fleming,
Strange [and I expect others] sells the U S Gear brand. I have installed several of that brand with good results and good service life.
If you want extra insurance you can have the gear set Cryo & REM treated at a cost about equal to the gear set.
Larry Woodfin 471W
Old 09-03-2015, 10:33 AM   #7
Dragsinger
Also, considering your application and it's performance range the out of the box gear set will most likely give acceptable service.
Larry Woodfin 471W
