Old 02-01-2017, 04:17 PM   #1
Mike Fuller
Liked 203 Times in 80 Posts
Default 12 Bolt 40 spline spool
I can not find anybody who makes these spools. I have one in my possession now and am considering making them if I can draw enough interest. Chime in if you have input about this topic.
Mike Fuller 396 STK
3961 SS
Old 02-01-2017, 04:35 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: 12 Bolt 40 spline spool
I don't think it would sell that well, in order to use the 40 spline spool, you need at least 3.250 bore housing. those are only available in a new aftermarket housings. the stock housings are 3.062 bore, . secondly the 40 spline I.d. on a 3.250 o.d. on the bearing is marginal for strength , thirdly if a 35 spline axle isn't enough for your application, you should be looking at a dana 60 or 9'' in my opinion.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 02-01-2017, 04:54 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Agree with Mark about a limited application. At the performance level of needing a 40 spline axle, the 12 bolt gear set is beyond the design limits.
Larry Woodfin 471W
Old 02-01-2017, 07:32 PM   #4
rx dealer
Liked 53 Times in 13 Posts
Mike, Strange makes one, It's for the 12 bolt drop out center section that fit a 9" housing.it's used by the comp guys. I have one in my Race car. I run a DTS 12 bolt housing with MPR chromoly tubes...Luke
rx dealer is offline   Reply With Quote
Old 02-01-2017, 07:57 PM   #5
Mike Fuller
Strange no longer makes it. Like I said I have one now and the application that you talked about is what I plan to use it for.
Mike Fuller 396 STK
3961 SS
Old 02-01-2017, 10:14 PM   #6
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: 12 Bolt 40 spline spool
There are bearings, that will fit a stock, 12 bolt housing bore. These bearings fit this 40 spline spool, plus the Strange & Mark Williams aluminum 35 spline spools. These are very expensive, aircraft landing gear bearings, but you do not have bore the housing, to use these spools. Google my name to find my contact information.
Eddie Rezac
Eddie Rezac is offline   Reply With Quote
Old 02-02-2017, 08:32 AM   #7
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
I have one for sale, $100 used but very good condition. 12 Bolt Chevy Ford drop out takes Strange axles.
Call me or PM if interested.
(631)461-6761
Old 09-14-2017, 02:44 PM   #8
jon jamison
I would like to buy one of these 40 spline spools for the Strange drop out 12 bolt carriers. New or used.
712 363 3801
jon jamison is offline   Reply With Quote
Old 09-14-2017, 10:27 PM   #9
rboyle
rboyle's Avatar
712 363 3801
Mike Fuller was the person that bought the one I sold. He may have them if you can contact him still.
Thanks.
Rich
Old 09-15-2017, 04:04 PM   #10
lotsohp
Also check with Frank Parks(Neal & Parks). They make and have many of the needed components.
lotsohp is offline   Reply With Quote
