Old 03-24-2017, 02:20 PM   #1
Joseph Teuton
Joseph Teuton's Avatar
Default Houston
Any news from Baytown?
JOSEPH TEUTON
4044 STK,SS,
Joseph Teuton is offline   Reply With Quote
Old 03-24-2017, 03:09 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Default Re: Houston
Live timing is running...link will get you in the vicinity then use the drop down menus to select 'qualifying order', etc.
http://www.nhra.com/results/2017/luc...er/super-stock
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-24-2017, 10:14 PM   #3
Brett C
Liked 1,022 Times in 218 Posts
Default Re: Houston
Sorry all, could not find Q sheets this evening. All classes got 2 runs in. All gamblers/bracket races were canceled. There were a few oil downs and a TS crash (no info), along with a few intermittent sprinkles this afternoon. Weather is supposed to rain overnight, so may be late starting depending on when it quits. Did not here who is at top of the lists. Sorry, all that I have.
Brett Candies
4192 Stock/SS
God Bless America
Old 03-24-2017, 10:52 PM   #4
Mike Meier
Liked 41 Times in 9 Posts
Default Re: Houston
I'm working on getting a decent copy of the Q sheets onto my computer. My work scanner isn't wanting to work with my personal lap top. Gimmie about 15 minutes.
Mike Meier
"World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough
Mike Meier is offline   Reply With Quote
Old 03-24-2017, 11:43 PM   #5
Mike Meier
Default Re: Houston
Friday saw 57 cars attempt to qualify. The one DQ was for old fuel. One car (Jackie Hibbard T/SA Maverick wouldn't start under the tower (coil went bad), he would have been 58. By time we were wrapping up, the Hidalgos rolled in so count 2 more Stockers and one more SS for Saturday.
Super Stock up next.
Name:	Fri Stock 1.jpg
ID:	38733   Click image for larger version
Name:	Fri Stock 2.jpg
ID:	38734   Click image for larger version
Name:	Fri Stock 3.jpg
Mike Meier
Old 03-24-2017, 11:50 PM   #6
Mike Meier
Default Re: Houston
Super Stock Qualifying after 2 rounds.
Only thing of note was that John Clegg had the "R" on his window to try and set the SS/AS record but only made a pass in the 2nd session.
Name:	Fri SS 1.jpg
ID:	38736   Click image for larger version
Name:	Fri SS 2.jpg
ID:	38737   Click image for larger version
Name:	Fri SS 3.jpg
Mike Meier
