Old 06-25-2018, 07:38 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Valve Spring Pressure - BBC stocker
My new motor 396/325hp stocker broke a valve first weekend out (had dyno time too), upon disassembly it was found that all 8 intake valves had been making light contact, of course it was one of them that broke.
My tightest ptv clearance upon assembly ( and checking again during autopsy) was .070" which should be plenty, which leads me to believe it must have been lofting the valves open due to lack of adequate spring pressure. Springs were setup to be 250# on the seat and 500# over the nose which all recommendations said should be enough. Obviously not however. Just wondering if any of you have suggestions of what we should set it up to this time. Cam is steel core, dlc coated trend lifters, pac 1325 springs and steel retainers. Fire away with any suggestions, and thank you.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-25-2018, 09:39 PM   #2
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Valve Spring Pressure - BBC stocker
Can I ask what it made on the dyno and the peak RPM HP?
Old 06-25-2018, 10:09 PM   #3
Chipper Chapman
445@5700. My dyno is known to be stingy, but it really should have made peak near 62-6300. Should have been the first clue but unfortunately it wasn't.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-25-2018, 10:34 PM   #4
Liked 1,877 Times in 422 Posts
If you indeed have 250# on the seat, and over 500# open, you have over 0.050" piston to valve clearance on the intake, and you have a valve control problem, then there is something terribly wrong. I can spin mine to over 8,000 RPM with those pressures, and a true 0.050" piston to valve clearance.
Old 06-26-2018, 07:34 AM   #5
nhramnl
Liked 358 Times in 83 Posts
I completely agree with Alan, but have a question. Is the camshaft you're using one you've used in the past without problems, or is it something new, perhaps with lobe profiles that are somewhat "exotic"? If the intake lobe ramp profile is too extreme, even with the kind of valve spring pressures and piston-to-valve clearance you're talking about, the lifter may not be able to stay in contact with the lobe, and you end up with an uncontrolled valvetrain. Just a thought.
Old 06-26-2018, 08:06 AM   #6
Chipper Chapman
This is what my fear is, When I called to have cam ground I had called Chris P when he was at crane, he left while my cam was to be done and it got shuffled over to comp and ground totally different than we talked, in a more aggressive fashion. I usually check the ptv the simple way with clay, but also checked it by opening valve with checking springs and degree wheel, same result both ways.
For reference camshaft is COMP .396/.396 lift, 288/294 .006, 248/254 .050 and on the big core
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-26-2018, 07:08 AM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
My tightest ptv clearance upon assembly ( and checking again during autopsy) was .070" which should be plenty......
Chipper, how was v-p clearance checked? Where was the contact on the piston? -Al
"That'll never work....."
Old 06-27-2018, 08:45 PM   #8
Jim Hanig
Liked 99 Times in 49 Posts
Question Re: Valve Spring Pressure - BBC stocker
[QUOTE=Chipper Chapman;566240]My new motor 396/325hp stocker broke a valve first weekend out (had dyno time too), upon disassembly it was found that all 8 intake valves had been making light contact, of course it was one of them that broke.
who told you needed 250 on the seat? I have ran several 396/454 oval port engines with no way near that much seat or open pressure. I wou call pac and get the correct spring.
Old 06-28-2018, 05:32 PM   #9
Darrin Christen
Darrin Christen's Avatar
[/QUOTE]I do not use clay to check. I check as run, complete the springs. Manley makes a tool to open the valve using the rocker arm. Check every 2 degrees between 25 degrees BTDC and 25 degrees ATDC. Your piston to valve clearance, as run, should be equal to or greater than your TOTAL piston to deck clearance. On the exhaust, you need 0.075", checked the same way.
Alan,
I know many people use this method for checking ptvc, but when you open the valve using the rocker arm to find the clearance you basically take all of the load off of the pushrod and lifter which doesn't account for any pushrod flex. Seems to defeat the purpose of checking the clearance in an as run situation. I do realize that the larger diameter and thicker wall pushrods would have minimal flex. Just a thought.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 06-28-2018, 07:49 PM   #10
Ed Wright
Ed Wright's Avatar
There ya go!! ^^^^^^^
I did not know anybody used modeling clay these days.
Ed Wright 4156 SS/JA
