Liked 13 Times in 4 Posts
hi working on pontiac 455ho stock eliminator with a single booster quadrajet that runs fat in first gear from 5100 -5900 afr 11-11.5 anyone know how to fix this. regards magnus
Liked 315 Times in 178 Posts
May be over rich with the secondary metering rods. The smaller the diameter of the rod the fatter you will be.
Liked 280 Times in 139 Posts
How is the carb set up,does it have primary rods and jets with the spring or just jets with no rods.Where's the float level?,fuel pressure?. gsa612
I just noticed it was a single booster carb.I believe it's only legal on a few cars yours being one of them.The guy you need is Danny Ashley,he's a member here,hopefully he'll see this.I don't have any current contact info,maybe someone here does. gsa612
Liked 239 Times in 114 Posts
There is a special system that the 1971 455 HO carb has , its called the POE system . Its purpose is to add extra fuel at WOT . You may want to get the Quadra Jet book by Cliff Ruggles , he has a section on that system . Most Q-Jets do not have that system , it doesn't meter fuel as well as having fuel go through the venturies . You say your engine only runs rich in 1st gear , are you running a Ram Air hood and air cleaner ? Which body style , GTO , Formula , or Trans Am ? Each has a different system .
Check Fig 11 https://www.gmcmi.com/wp-content/upl...ice-Manual.pdf Last edited by ss3011; 08-23-2018 at 09:07 PM. Reason: Added Link |
Liked 16 Times in 5 Posts
May be sloshing fuel out of the secondary metering rod holes. Do you have them sealed with tape or anything?
Guest
Posts: n/a
Danny is retired and living the quiet life, have to find somebody else.
Liked 132 Times in 27 Posts
Try Dean Oliver #870-830-5470
the car is a 1972 lemans no ramair hood no aircleaner no primary rods just jets secondary metering rod holes are sealed float level 1/2 in fuelpressure 6psi accelerating well tubes are blockt afr 12.5-13.5 in second and third gear. regards magnus
Was the float level and the accelerator well tubes modified that way to try and fix this rich problem ? Not sure what you are talking about when referring to accelerating well tubes . Are these the tubes that are supposed to feed fuel into the secondaries as the flaps start to open ? Also when you are on the 2 step , are you flooring the accelerator pedal ?
