Old 09-24-2019, 11:57 AM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Jericho trans question
Can one of these trans used in a stocker be used on the street? Hemi 18 spline trans are $2000 and up. That much into a trans might as well step up to a better one.
Mike
Old 09-24-2019, 01:39 PM   #2
t.tosto
Liked 62 Times in 23 Posts
Default Re: Jericho trans question
Can be used on the street, just exercise "double clutch'' technique on up/downshifting to extend trans. life. Full throttle shifts, same as on track. Tony
t.tosto is offline   Reply With Quote
Old 09-24-2019, 02:57 PM   #3
Coleydog
So, no synchros huh?
Old 09-24-2019, 06:44 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Talking Re: Jericho trans question
you can do it,if you have truck driving experience with a 10 speed that will help the learning curve ,, oh lots of gear noise !
Old 09-24-2019, 06:59 PM   #5
BILL TAYLOR
Liked 200 Times in 62 Posts
I wouldn;t do that, never had any luck shifting it slow !
BILL TAYLOR is offline   Reply With Quote
Old 09-24-2019, 08:56 PM   #6
J&S Racing
Liked 327 Times in 87 Posts
Was wondering this.. if there’s a sweet spot to “float” or RPM match shifts??
Old 09-24-2019, 09:11 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
You won’t have any problem shifting that transmission on the street. It is face tooth design and you won’t need to use the clutch. Just ease off the throttle and move the shifter smoothly and quick. The straight cut gears will be noisy and down shifting should not be done. It will wear pretty fast.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
