Liked 75 Times in 28 Posts
Looking for recommendation on which lifter and why?
Trend or Precision? Would you get them DLC coated? |
Liked 72 Times in 27 Posts
They will be on a steel cam.
Liked 169 Times in 53 Posts
why can you not run the coated lifters on a cast cam.?
Bill Bogues 4696 STK |
Liked 132 Times in 27 Posts
Would you get the EDM hole in the face of the lifter?
Liked 510 Times in 117 Posts
Ppp lifter have a coated lifter with a coating that is safe for a cast cam. In my spare engine I took out the shubeck grenades and installed them on a cast cam. Broke them in as if it was a new cam and lifters with break in oil. Valve setting never moved. Took them all out after to inspect them and they looked like they came out of the box.
68 Chevy11 327 F/S |
![]() You should be more specific as regards to the type of coating. There are some coatings that can be used with cast camshafts. However, DLC coated lifters can only be used with a properly finished tool steel camshaft core. |
