Liked 51 Times in 30 Posts
Hello,
what are you using for rear axle assy for L M/SA? 4000lb car, will a 8 1/4 work? c-clip? 4:88's ? I can deal with changing ring/pinion each season just don't want to spit pinion out on starting line building 1975 cordoba 400 4V for L/M thanks gary |
#2 | |
Liked 108 Times in 29 Posts
Drop out center section. Will hold up for a long time. |
I run a N/O/P Mopar
@ 3500 to 3700 Lbs. I would strong recommend to 8 3/4 The 8 1/4 is had to find gears for and really much weaker! Even in the Mid 70's Larry Shepard at the Mopar Performance Seminars strong recommended losing the 8 1/4 He stated that Mopar save a little over a single dollar when they replaced the 8 3/4 with the 8 1/4. I guess every dollar counted with a Mfg. that was bleeding money at that time!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-01-2021 at 10:21 PM. |
My boy runs a 400 Roadrunner usually in I/SA at around 3700 Lbs
We have broken several expensive 8 3/4 third members before we went to a Dana 60.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-01-2021 at 12:12 AM. |
Liked 129 Times in 53 Posts
It's the weight you should go by,Heavy = Dana
Based on my observations a 283 in a heavy Car could be thougher on rears than a 396/427 in a lighter car. Trying to move a lot of weight from standstill in a hurry is what takes a toll on stuff. My experience with 8 3/4 is that they start breakin up around 3500 pounds and even earlier if you have some serious power. Then some say the Dana is faster also...sorry about the rambling,your question was about the 8 1/4 and 8 3/4 and I have zero experience with the first one!
Stop global whining Last edited by Race Clean; 04-01-2021 at 10:19 AM. |
Liked 124 Times in 44 Posts
My experience is with the length. Axle tube flex caused most of the failure.
