Old 04-27-2021, 09:29 PM   #1
rod
Liked 20 Times in 15 Posts
Default dist. rotor ?
I just got a new cap & rotor from MSD. the rotor is the old Chevy point type. it has the short 'E' brass tip. which has close to 1/8" gap between the tip and the cap terminal. I know GM used this 'E' rotor for emission engines [thus the E]. doesnt the large gap make it harder on the coil? what is the real purpose of the larger gap?
before I set about modifying the new one, I want to why I shouldnt!
thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-27-2021, 09:43 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: dist. rotor ?
Rod, my understanding having a large cap it helps to not get a miss fire. On the small cap an Arc could jump to either terminal next to the one to be fired. When running on motor and turning on nitrous timing is retarded. With the large cap you can do it safely and not misfire. That's bad on nitrous if it misfires.
Old 04-30-2021, 09:16 PM   #3
doug schriener
Liked 7 Times in 6 Posts
thanks Rod in AZ
Rod-We ran that setup on the 85551 billet distributor on my drag car and our IMCA stock cars with zero problems. Doug Schriener
doug schriener is offline   Reply With Quote
Old 05-04-2021, 12:51 PM   #4
Henrys Toy
Liked 520 Times in 176 Posts
thanks Rod in AZ
With todays ignition coils in a drag car the wide gap is no problem and does help ever so slightly. I've been using that exact set up in my stocker for more then 30 years with a MSD 7al2 without any ignition or coil issues. After 2 or 3 seasons I change it probably out of guilt that I wouldn't want to lose a round of racing over a $5.00 part.
Henrys Toy is offline   Reply With Quote
