Old 07-02-2021, 11:31 AM   #1
Bryan
Default Retiring from Racing Garage sale
1. Chev 350/300 HP S/S Motor
GM Stock filled block 4.070 Bore
Gm Forged Crank
Bullet Cam 276/283-04 Stock Bearings
Manley Rods
186 Ported Heads non Welded & Raised EX Ports
ARP Head Studs
New Manley Valves 200" Long
CP Pistons
Comp Cam Belt Drive
ATI Balancer
Jessel Shaft Rockers 1.8 INT 1.6 EX
Victor E Intake Epoxy Matched to heads
Moroso Oil Pan W/ Heat Pad
MSD Crank fired ignition
$ 8,000 Fresh Off Dyno
2. Chev 350/300 HP S/S Motor
Bowtie Block 4.060 Bore
Scat F43 Lightweight Crank 1.888
Manley Tour Lite Honda Rods 1.888
CP Pistons .027 Rings
ATI Balancer
Comp Belt Drive
Comp Cam 276/284-107 Stock Bearings
ARP Head Studs
New 041 Voges Heads
Ferrea Valves
Pac Springs
Super Victor Intake Voges
Moroso Oil Pan w/ Heat Pad
$ 14,000 Fresh Dyno Time Only sold
3. 9" Ford Strange Aluminum Center Section w/ Carrier box
40 Spline Spool 6.0 Richmond 9310 Pro Gear 1350 yoke
Perfect condition 40 Runs $ 1,000 sold
4. 9" Ford Strange Aluminum Center Section
40 Spline Spool 6.20 Richmond/Gleason Pro Gear 1350 yoke
Perfect condition 30 Runs $ 1,000 sold
5. 9" Ford Dewco Aluminum Center Section w/ Aluminum Carrier Box
6.0 Lightened Pro Gear Richmond/ Draw Through Carrier Bolts
40 Spline Spool 1350 yoke
Perfect condition 25 Runs $ 1,500
6. Jerico DR-4 Trans w/ Long Shifter- T handle 18 spline
1st 3.19 2nd 2.00 3rd 1.39 4th 1.0
Perfect Condition No Issues $ 2,500 sold
7. 9" Ford Ring & Pinion 6.20 Richmond/Gleason Lightened Pro Gear
Perfect Condition $ 250 sold
8. McLeod Clutch Set up / Black Magic Rebuilt 18 spline
10-1/2 Aluminum Flywheel/ Pressure plate & disk w/ T.O Bearing
Fresh 0 Runs $ 1,500
9. Q-Jet Race Carb 7029207
Good Condition $ 100 sold
10. Q-Jet Headworth Race Carb 7029207
Good Condition $ 400 sold
Contact Gary 801-969-9052
Email gary7525ssh@gmail.com
Bryan is offline   Reply With Quote
Old 07-02-2021, 08:13 PM   #2
L.Fite
Liked 494 Times in 241 Posts
Default Re: Retiring from Racing Garage sale
Email sent.
L.Fite is offline   Reply With Quote
Old 07-02-2021, 08:56 PM   #3
joe collins
Liked 22 Times in 16 Posts
what input shaft is in the jerico
joe collins is offline   Reply With Quote
Old 07-04-2021, 07:21 PM   #4
billy wilson
Email sent
billy wilson is offline   Reply With Quote
Old 07-04-2021, 08:51 PM   #5
Chesrown
Gm Forged Crank
Manley Rods
ARP Head Studs
CP Pistons
Comp Cam Belt Drive
ATI Balancer
ATI Balancer
Comp Belt Drive
ARP Head Studs
New 041 Voges Heads
Ferrea Valves
Pac Springs
The Jerico been sold yet?��������
Chesrown is offline   Reply With Quote
