Old 08-03-2022, 08:01 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Fast EFI 2.051 internal datalogging issue/setup
Trucks ECU got used to tune the dart, now its starting to datalog too early.
Truck uses a brake pressure switch for the two step.
Two step RPM is controlled by ignition box ie msd, we don't use fasts internal two step.
Now its starting to datalog the second the brake pressure switch is tripped(burnout)
I can only get it to datalog with it setup with manual trigger, and PA enable.
Could it be the firmware?
I think you should be able to seupt the internal datalogger without a switch ie set trigger point to 95% TPS, and arm it with PA enable, Aux 7 is a switch.
Thanks
Eric
Eric Merryfield 1883 STK
Old 08-04-2022, 11:34 AM   #2
Jim Whitehead
Liked 150 Times in 41 Posts
Default Re: Fast EFI 2.051 internal datalogging issue/setup
Eric Are you Pulsing power or ground on the switch ? Aux 7 should be on a momentary switch to arm the system and set TPS to trigger.
Jim Whitehead is offline   Reply With Quote
Old 08-04-2022, 01:53 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Thanks
Eric
Put switch 12v to pink wire for pa enable and configure to trigger on tps percent. Any time you make a change to data log configuration you have to select configure internal data logger.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
