Old 11-01-2022, 09:12 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Default Block Honing
Who is a good machinist to hone a block for a stocker? Would like to find someone using the newer CNC honing equipment. Preferably in the SE. Just let me know what you recommend.
Thank You
Robert
Robert Simpson is offline   Reply With Quote
Old 11-01-2022, 10:26 PM   #2
MR DERBY CITY
Liked 8,052 Times in 1,529 Posts
Default Re: Block Honing
I am sure that Randy Daniels OR the Warren family would be up for the task.
Old 11-01-2022, 10:59 PM   #3
J.R. Haddad
Liked 1,471 Times in 308 Posts
Make sure they have new or newer Rottler Honing machines, if not walk
away, regardless of what your told.
JR
J.R. Haddad is offline   Reply With Quote
Old 11-02-2022, 12:19 AM   #4
SBillinson
Liked 183 Times in 48 Posts
JR
So a Sunnen SV-10 or 15 is a POS?
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 11-02-2022, 05:03 AM   #5
Liked 10,820 Times in 2,249 Posts
Diamond stones work well
Old 11-02-2022, 07:29 AM   #6
Frank Castros
Liked 2,741 Times in 967 Posts
Weston Machine Piscataway NJ
Old 11-02-2022, 09:59 AM   #7
TONY C 2200SS
Thank You
Robert
robert give me a call tony conte 727 531 6313
TONY C 2200SS is offline   Reply With Quote
Old 11-02-2022, 11:18 AM   #8
340Cuda
Liked 805 Times in 341 Posts
If I was having a block honed I would sent it to Brad Lagman at QMR.
https://qmpracing.com/
However he usually has a pretty big backlog.
Old 11-03-2022, 08:06 AM   #9
A profilometer is a must to get the desired finish on the cylinder walls. Jeff Taylor’s shop does a good job of hitting the numbers. New Sunnen SV 10 with the screen.
To get the best work possible have a set of old mains installed and torqued to keep the block bores from getting dinged. Have an old set of head gaskets the correct thickness and make to go under the torque plates, yes one on each side if possible. It probably makes no difference but I assign bolt and or stud placement. Over the years I have my own torque plates.
Another great shop is BES in Indiana.
Old 11-03-2022, 10:13 AM   #10
Liked 1,879 Times in 422 Posts
They're pretty far away from you, but we use Day Enterprises, just north of Nashville TN. Chris Amos does our work, and Day Enterprises has the new Sunnen CNC hone.
